Results 1 to 7 of 7
    ROG Member Array
    Feb 2014
    18
    Direct CPU cooling on Maximus X Formula?
    I'm curious if anyone has any experience with delidding and cooling the CPU directly with the Maximus X Formula?
    I'm considering doing this with an 8086k to get better temps, but after watching this video, I am concerned that the socket may not allow for the block to come close enough to the CPU to make contact without an IHS. The issue he had was with the raised corners on the socket being slightly higher than the chip itself.
    ROG Member Array rick66 PC Specs
    rick66 PC Specs
    MotherboardASUS ROG Maximus X Formula
    ProcessorIntel Core i7 8086K Delidded @5.3 Ghz
    Memory (part number)Corsair Vengeance LED 32GB 3000Mhz(CMU32GX4M4C3000C15)
    Graphics Card #1Gigabyte AORUS GeForce GTX 1080 Ti Waterforce WB Xtreme Edition
    MonitorASUS ROG PG278Q
    Storage #1Samsung 860 Pro 512GB (OS)
    Storage #2Samsung 970 Pro 512GB M.2 (Games)
    CPU CoolerThermaltake Pacific W4 Plus
    CaseThermaltake View 71
    Power SupplyCorsair HX-1200i
    Keyboard Razer BlackWidow
    Mouse Razer Taipan
    OS W10 64
    rick66's Avatar
    Jun 2014
    12
    I delidded my 8086K last week, i`m using a Thermaltake Pacific W4 water cooling block and have no issues with cooling, Idle temps @ 5.3Ghz OC are 27 deg cels and RealBench stress test showed 71 deg max.. I couldn`t be happier with the results. Heres a link too the IHS i used. And here`s a YT guide i used.
    ROG Member Array
    Feb 2014
    18
    I was asking more about not using an IHS, and using a delid die guard. Thanks for the IHS info though, hadn't seen those.
    This is my concern here. The corners of the socket.
Name:	block corners.jpg
    Nate152 PC Specs
    Memory (part number)16GB G.Skill Trident Z 4000MHz 16-16-16-39-2T
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Power SupplyPC Power & Cooling Turbo Cool 1200w
    Keyboard Razer Anansi
    Mouse Logitech G500
    Headset Sennheiser HD6XX
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,351
    Hi Brack
    I would delid it with thermal grizzly conductonaut and relid the IHS with heat resistant sealant.
    Risk to reward isn't worth it, look at rick66's numbers. I delidded my 7700k and gaming temps at 5.2GHz with 1.440v are 50' - 60's. You won't be running it with much more voltage than 1.44v - 1.45v anyway which you can easily do with delidding + IHS and a good cooler.
    Vcore is the cpu voltage
    ROG Member Array
    Feb 2014
    18
    Hmm that's probably a good point of risk vs reward. I'm not even pushing >1.4v anyway right now.
    I've seen recommendations of using something to seal any contacts on the top of the silicon if using conductive paste inside the IHS, like clear nail polish. Is this really necessary?
    rick66 PC Specs
    Mouse Razer Taipan
    OS W10 64
    rick66's Avatar
    Jun 2014
    12
    Quote Originally Posted by Brack View Post
    It`s imperative that you seal any contacts on the cpu from thermal paste that may escape the dye onto the circuit board, you must also chose a clear top coat nail polish that has no formaldehyde , a natural polish is what you need other wise it conducts. I used Sally Hansen Color Therapy Top Coat.
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,351
    I go through the process of delidding the 7700k if you'd like to see it, it's not necessary to use nail polish at least I didn't use any but could be a good precaution.
    Thermal Grizzly Conductonaut is the liquid metal for between the cpu die and IHS, the Kryonaut goes between the IHS and water block. These are probably the best on the market.
    Start here on page 9, 6th post down.
    https://rog.asus.com/forum/showthrea...ed-7700k/page9
