Question if that would be even possible.
jan_case
I am setting up a ASUS Gaming PC at the moment an was wondering about the technical possibilities of an idea I had.
What I would really want to use is a dynamic wallpaper that changes its colors with AURA Sync. Like the ROG logo that changes its Colors based on what your Aura setting is. Even cooler would be something like the popular Wallpaper Engine from*Kristjan Skutta where you have moving wallpaper images (just videos in a loop) that can change their hue / color values with Aura sync. Would that be even possible to do with the SDK in any way?*
Korth
Level 14
Technically possible, yes, and not particularly difficult.
But I'm not aware of any software which coordinates software customizations with matching hardware RGB themes, I don't think the AURA SDK (or any other RGB application) currently supports anything like this. I think you'd have to write your own.
[/Korth]
