Results 1 to 7 of 7
    ROG Guru: Yellow Belt Array Denna PC Specs
    Denna PC Specs
    MotherboardAsus Maximus VI Gene
    ProcessorIntel i7-4790K
    Memory (part number)Corsair CMD8GX3M2A2133C9
    Graphics Card #1MSI GTX970 Gaming 4G
    MonitorAsus VG248QE
    Storage #1Samsung 840 Pro
    CPU CoolerCooler Master Nepton 140XL
    CaseCorsair Obsidian 350D
    Power SupplyCorsair AX760
    OS Windows 8.1 64-bit
    Mar 2014
    25
    125
    Question How do you choose an RTX 2070 manufacturer, make and model for overclocking ?
    When selecting a video card for GPU intensive gaming, how can you tell which card is durably built to last while overclocked ?
    Nearly every GPU manufacturer has a gaming brand meant for demanding GPU applications. For Asus, it's the Strix lineup.
    I don't think many people consider how overclocking affects the life expectancy of a video card.
    It's all about trying to get a video card to support an application's highest settings.
    The selection process usually begins with finding the most performance within a specific price range.
    After having read many GPU reviews over the years, it appears component quality can vary on the same video card.
    Do you have to use an Nvidia 80's series card to have better component quality ?
    Is there a video card manufacturer that routinely over engineers their video cards to support a long life expectancy while overclocked ?
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Steelseries Prime+
    Mouse Pad Steelseries QCK Prism XL
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,443
    Hey Denna !
    To answer some of your questions
    Nvidia has the voltage capped (1.093v for pascal) and GPU Boost 3.0 will throttle your gpu if the power target or a certain temperature is met, so basically it is Nvidia's way of idiot proofing them. Aside from that any overclock you can get is free performance, the Strix 1070 averages a 10 FPS gain at 1440p.
    With GPU Boost 3.0 you want one that has good cooling, otherwise you could run into temp issues which leads to throttling. A water block will help sustain high overclocks if fans can't do the job, the Strix gpu's have great coolers and have a reputation as being one of the best.
    As far as longevity goes, it will still last a lifetime because Nvidia limits the voltage, (1.063v stock to 1.093v isn't much) and will throttle clock speed if temp gets too high. I'm not sure what it will be for Turing but I imagine those will use GPU Boost 3.0 - 4.0 too.
    The cooler, the better !
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,718
    You usually can't tell a whole lot in advance, only enough to narrow your list by excluding products which fall outside your specs or budget.
    Reference cards are built to reference spec, of course, while factory-overclocked cards will have higher clocks than reference, of course. But no real way to tell beforehand how much higher they can go.
    Good reviews will give you an idea of what to expect, especially if many reviews compare many cards. The best reviews will provide some takeapart/analysis to show you what sort of hardware is involved. The card maker rarely modifies the core basics - GPU ASIC and VRAM, etc - but often improves the VRMs and cooling hardware so that the core parts can reliably be pushed harder and faster. Nonreference ASUS cards tend to have quite robust power and cooling hardwares, STRIX and MATRIX/POSEIDON/etc cards tend to consistently do well on overclocking.
    My personal experience - which is not truly extensive - is that when a manufacturer offers different tiers of the same product then you'll almost never be able to push a lower-rated and cheaper version to the specs offered by the next-higher-rated and more costly one, the manufacturer binned parts and of course doesn't use the best ones on products which sell at lower costs. Yes, an argument can be made that sometimes manufacturers will deliberately low-bin the better stuff to fill demand on the faster-selling stuff ... but don't count on it and don't be disappointed if you lose a gamble based on this hope/expectation, some people always win this game (and some try to play the multiple-RMA-reroll game until they get better results) but the vast majority only get exactly what they paid for. The corollary is that when you buy a card from a manufacturer which doesn't pre-bin for multiple card models then your chances of lucking out on epic parts are (theoretically) better.
    Silicon yields - so-called "ASIC qualities" - also improve over time. Later-run parts tend to have better overclocking thresholds and power efficiencies than early-run parts. Later-run parts also tend to have more reviews and "under the hood" information available online. There's just no real way to know how well first-wave cards are going to overclock in advance. The premium on factory overclocks is highest on the very earliest products and on the very best of the best of the latest products within any card family - you could pay +100% price for +15% performance, it would be smarter to SLI/CF a second card!
    [/Korth]
    ROG Guru: Green Belt Array Heini PC Specs
    Heini PC Specs
    MotherboardAsus SABERTOOTH Z170 MARK 1
    Processori7-6700K
    Memory (part number)G.SKILL TridentZ (2 x 16GB) F4-3000C14D
    Graphics Card #1Evga 2080Ti XC Ultra
    Sound CardAsus Essence STX II
    MonitorASUS MG279Q
    Storage #1Samsung 950 Pro 512GB
    CPU CoolerNoctua NH-D15
    CaseCooler Master HAF XB EVO
    Power SupplyEVGA SuperNOVA G3 1000W
    Keyboard Ducky Shine 6 (Brown Cherry MX)
    Mouse Secret (Ducky)
    Headset Sennheiser HD 580
    Mouse Pad EVGA TORQ
    Headset/Speakers Logitech Z906
    OS Win10 Pro 64
    Heini's Avatar
    Nov 2013
    50
    600
    For OC'ing with temps and mfg support in mind I'd choose between ASUS & EVGA. ASUS cards run cooler and OC a little better (on avg.) but EVGA's rma procedure is great.
    Denna PC Specs
    MonitorAsus VG248QE
    Mar 2014
    25
    125
    Nate152, Korth and Heini,
    Thanks for the detailed responses.
    Does anyone see reduced video card life expectancy when increasing power and voltage with a vBIOS mod - with adaptive power management enabled ?
    Korth PC Specs
    MonitorASUS PG278Q
    Korth's Avatar
    Mar 2015
    152
    2,718
    Short answer: warranty is usually 3 years and usually requires that the card isn't ever operated outside rated limits or ever taken apart. Different manufacturers have different products and different warranty policies, it's worth comparing all your alternatives because even if you never make a warranty claim you can at least get a rough measure in how confident the manufacturers are in their own products (or in sustaining customer loyalty).
    Yes, overclocking your card voids warranty in the strictest definition, but the manufacturer may choose to honor warranty on failed OC parts nonetheless - at their discretion, on a case-by-case basis.
    These days there are tamperproofing indicators built into firmware. They know if you've deliberately explicitly clicked YES YES YES on the software, they know if you've bridged that LN2 jumper, they know if you've modded the VBIOS. They probably don't know if you've physically volt-modded the thing, but it's probably a safe bet to assume they do if you plan to lean on warranty coverage to replace/repair failed parts.
    [/Korth]
  7. #7
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    170
    2,193
    It can be difficult pre-launch to make an informed decision, which is why it's always a good idea to wait. NVIDIA are now opposed to vendors touting hire clock speeds out of the box, too. So it's down to both cooling performance and build quality.
    The Dual, Turbo and even the Strix to an extent have the benefit of being shorter in length than some of the other vendor parts. One model from MSI comes in at over a whopping 33cm, which will be too big for some builds.
