Results 1 to 2 of 2
    ROG Member Array
    Feb 2012
    5
    popping noise from left speaker?
    i just bought my g74sx-rh71 a few days ago, and for some reason the left speaker will randomly make a loud annoying "pop" every 2 to 5 minutes. has anyone else had this problem? if so do you know if it is a hardware problem or some other fix? i appreciate all the help i get on these forums, you guys do an awsome job. thanks
    ROG Guru: Blue Belt Array fuzon1337's Avatar
    Sep 2011
    18
    878
    Hi
    Take a look at this site. It sounds like the realtek driver is the source of your issue.
    In that link, you can see how to fix it
    Or if that isn't your issue, then you could take a look at this site.
    Asus G73SW-91058V 3D
    - Intel Centrino Ultimate-N 6300
    - BIOS 205
