Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    ROG Member Array mojoeskimo's Avatar
    Aug 2018
    9
    Angry Low gpu usage and low frames in game! Help!
    Okay computer gurus here we go!
    I have a new rig(specs below) and it has been doing fine for a month, but now all of a sudden I am getting very low frame rates in games(19-30 fps) on any settings....that before were running smooth 120+ fps on high to ultra settings. My GPU utilization hovers around 30-40%. My CPU seems to do fine and has no sign of throttling.
    OS: Win10
    CPU: i7 8700K
    GPU: Asus ROG STRIX 1080ti 11GB
    Mobo: Asus ROG STRIX Z370-E
    RAM: 1x DDR4 16GB
    SSD: Samsung 500gb
    PSU: Corsair CX750M
    Moniter: 32in Acer Predator 1440p @ 165hz
    I have no overclocking settings active and I have all updated drivers and updated bios. I have assured that my power settings are all set to performance. I use gsync (vsync off) and use 'gaming mode' in GPU Tweak II. Its been kinda frustrating and I have been trying to diagnose/fix the problem all day. Like i said, the rig ran fine not long ago on these same settings and was using the GPU fully. Let me know if you guys want some benchmarks and/or screenshots of values. Thanks in advance!
    Aug 2018
    9
    Some screenshots and FYI I have no idea what to look for when it comes to most of these values and what optimal is.
    Nate152 PC Specs
    Memory (part number)16GB G.Skill Trident Z 4000MHz 16-16-16-39-2T
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Power SupplyPC Power & Cooling Turbo Cool 1200w
    Keyboard Razer Anansi
    Mouse Logitech G500
    Headset Sennheiser HD6XX
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,351
    Hello mojoeskimo
    Welcome to the ROG forum.
    Yep, there's something definitely wrong with a score that low. First thing I notice is the memory is running at the proper speed of 11,000MHz but the core clock looks to be boosting to only 1278MHz. Superposition is showing 100% gpu utilization.
    Temps aren't a problem at 52c - 56c.
    1 ram stick is probably hindering performance some but I'm not sure it would that much.
    Post us a screenshot of GPU-Z, maybe this will tell us something.
Name:	GPU - Z.png
    Aug 2018
    9
ID:	75655Click image for larger version.
    All of these were captured under load or while i was in game (Day of Infamy) which should be a breeze for my system, was getting 160-190 fps previously.
    Aug 2018
    9
    Unhappy
    just makes me cringe... here is what user benchmark is saying...
    I wouldn't suspect my gpu be a bad card beings it worked flawlessly already? I put my gtx960 in this rig and it runs fine. I just don't get it.
    THINGS I HAVE TRIED:
    -enable and disable all OC
    -settings on performance (bios,windows,and nvidia control panel)
    -DDU and reinstall drivers
    -Made sure bios and all mobo related drivers were up to date
    -tried installing previous nvidia drivers
    -completely unplugged gpu and reinstalled fresh
    -fresh install of windows/factory reset
    -tried different refresh rates (60hz,100hz,144z)
    -turned of any resolution scaling
    -made sure applications were selected as priority
    -checked all physical power connections(leds all showing good)
    -ran gpu bare bones with geforce experience and GPU tweak uninstalled)
    No Luck, I have been testing and lately my gpu percentage will randomly shoot up to around 80% for maybe a second or two while tabbed out of a game and then fall back down to like 20%. Why would it fluctuate so bad? and is it normal for my CPU to be utilized at like 7% while in game? seems like it should be higher IMO.
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,351
    I see the bus interface is PCIe x16 3.0 @ x16 1.1
    Does it ramp up to 3.0 under load ?
  7. #7
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,801
    Hover over the green on the PerfCap Reason graph, otherwise, it's not telling us anything.
  8. #8
    Aug 2018
    9
    Quote Originally Posted by Nate152 View Post
    I am at work at the moment so I can not re-test untill this evening, but that screenshot was captured while in game, so my suspicion is that it does not ramp to 3.0.*
  9. #9
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,351
    OK, double check the bus interface is ramping up to 3.0. If it's not, try setting the pcie x16 slot to Gen 3.
    Here's my Superpostion score with 4k optimized, I would expect you to be somewhere in the 10,000 point range.
Name:	Superposition 399.24.png
  10. #10
    Aug 2018
    9
    Quote Originally Posted by Silent Scone View Post
    nothing comes up when I hover my mouse on the green, although the "pwr" reading is what it reads the whole time described by GPUZ as "limited by total power limit"
Tags for this Thread
