Results 1 to 7 of 7
    ROG Member Array Patricko's Avatar
    Aug 2018
    6
    Exclamation Laptop GL703GE - weird noises from battery?
    Hey there.
    I don't know if it's me or this noises sounds kinda weird... It's not HDD because sound goes more from the battery side.
    The sound stops when I disconnect charger cable, so is it really from battery? Is that normal?
    I'm also set battery charging to maxium lifespan mode (60%), so maybe that's the problem? But once again... Is that normal even with maxiumum lifespan mode enabled?
    Here is a video of this noises:
    https://youtu.be/QvPkvtaM3D0
    ROG Guru: Orange Belt Array FULLMETALJACKET7's Avatar
    Mar 2018
    46
    492
    That's normal, it's called coil whine.
    Aug 2018
    6
    Ok, thanks for clarifying That's a relief.
    ROG Member Array
    Sep 2018
    6
    Not normal!
    Quote Originally Posted by FULLMETALJACKET7 View Post
    Seriously?! Thats considered normal? I've got headache after working for a week with this thing! I tried dell G3 3779 with exactly the same specs just before buying gl703 and it had nothing like that! In fact thats the first laptop that does that, and I've had quite a few of those.
    So I'd say this is way out of normal, especially for its price tag!
    Mar 2018
    46
    492
    Quote Originally Posted by SithV View Post
    It is "normal", yes. They all come out of the factory like this. It's not like this one in particular has a malfunction. It's bad, I agree, but they're like this by (bad?) design. You can RMA as many times as you want, all of them will have the same damn noise coming out of it.
    My GL502VSK also has coil whine (only when idling), but it doesn't really bothers me since it's not too loud and I'm pretty much always using a headphone.
    My good old Lenovo Y510p also has a coil whine that comes from somewhere around the CPU since 2013 when I bought it. Still working perfecly.
    Edit; as a side note, if I change my mouse polling rate to 125hz, the noises pretty much go away. At 1000hz the noise is very noticeable. If the CPU is under load, the noise also goes away. Changing the power mode to "power saver" also makes the noise stop.
    New ROGer Array
    Jan 2019
    3
    Got the same problem here, and I've found a solution without loosing too much turbo boost.
    Just go in windows mobility center and change the battery status from balanced to power saver and you get rid of the noise
  7. #7
    ROG Enthusiast Array TopOkay's Avatar
    Dec 2018
    26
    Quote Originally Posted by Patricko View Post
    Hey there.
    As said, it's coil whine, check this for as sort of solution:
    https://rog.asus.com/forum/showthrea...ge4#post749830
