Results 1 to 3 of 3
    ROG Junior Member Array
    Jan 2018
    4
    Asus ROG GL553VE stuttering and masive FPS drop issue
    Hello guys I have some issues while gaming on my laptop.After a while in games or in some cases from the moment I start the game I get stuttering and masive FPS drops even tho the FPS counter in the game says its over or around 60.This happens in games that on my old crappy laptop I could run with no issues.An example, in Destiny 2 with everything on low and lowest resolution with render scaling down to 75-80(game already looks like pixels mashed togheter) I can play with no issue for about 30 minutes after that it goes to hell.I dont know what to do,I'm thinking its from overheating or maybe lack of ram because with the specs it has it shouldn't struggle so much with games.
    The specs are:
    -Intel Core i7 7700HQ @ 2.80GHz
    -8,00GB Single-Channel Unknown @ 1196MHz (17-17-17-39) DDR4
    -ASUSTeK COMPUTER INC. GL553VE (U3E1) Motherboard
    -Generic PnP Monitor (1920x1080@60Hz)
    Intel HD Graphics 630 (ASUStek Computer Inc)
    4095MB NVIDIA GeForce GTX 1050 Ti (ASUStek Computer Inc)
    ForceWare version: 399.07
    SLI Disabled
    -232GB Western Digital WDC WDS250G2B0B-00YS70 (SSD)
    931GB Hitachi HGST HTS721010A9E630 (SATA)
    Thanks in advance for any info
    ROG Guru: White Belt Array TimeLion724's Avatar
    Jan 2018
    114
    I have the same laptop model as you and have played Destiny 2 for hours but in medium settings.
    " The speed of the fallen one does not change..."
    GUIDE TO FIXING BSOD ERRORS
    ROG Guru: Yellow Belt Array SK8 PC Specs
    SK8 PC Specs
    MotherboardMaximus XI Extreme
    ProcessorIntel I9 - 9900K
    Memory (part number)DDR4 G.Skill Trident Z RGB 4266Mhz 32GB F4-4266C17Q-32GTZR
    Graphics Card #1ROG Strix OC 2080Ti
    MonitorSamsung 49" CHG90 QLED Gaming Monitor 144Hrz 1ms
    Storage #1Samsung 850 Pro X-Three-1TB
    CPU CoolerHydro Series H150i Pro RGB 360mm Liquid CPU Cooler
    CaseCorsair Obsidian Series 1000D
    Power SupplyCorsair HX 1200i
    Keyboard Corsair K70
    Mouse Corsair Sabre
    Headset Sennheiser Game Zero Headset
    Mouse Pad Corsair MM800 RGB POLARIS
    Headset/Speakers Sennheiser GSX 1000 Audio Amplifier
    OS Win 10 Enterprise 64bit
    Accessory #1 Logitech G13 handpad
    SK8's Avatar
    Jan 2016
    143
    It sounds like a setting is set wrong to me, sadly this is not a game I have played so I don't know its in game video settings :/ But to try and help make sure in Nvidia control panel , under 3D settings , Adjust image settings with preview is set to Performance to start with always.
    In game video settings if the game has this make sure this stuff is Off and if the game does not allow Off then set to Low... Supersampling (SSAA) OFF , Ambient OCCLUSION - OFF, FX AMOUNT OFF
    With all origin games turn off origin in game and cloud storage both give issues in games at times
    On PC power always set to high performance
    Other things to give low FPS and stuttering on a pc is programs so use a clean boot please see this link for steps if you need it...
    https://support.microsoft.com/en-ca/...oot-in-windows
    Bios 602
    passed 8hr test on Karhu RamTest
    Set to Manual OC
    Dram Frequency 4266MHz
    Dram voltage 1.45v
    CPU VCCIO Voltage 1.25v
    CPU System Agent Voltage 1.29v
    Dram timing control 17-18-18-38
    Mode1
    Dram command rate set to 2N set dram current capability to 130%
Tags for this Thread
