Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    ROG Guru: Orange Belt Array Rob W. PC Specs
    Rob W. PC Specs
    MotherboardRog Asus Rampage vi extreme
    ProcessorIntel i9-7980x Oc 4.6ghz 24/7
    Memory (part number)64 gb GSkill 3600mhz (8x8) 15,15,15,35
    Graphics Card #1nvidia Titan V + ekwb custom loop
    Graphics Card #2nvidia RTX 2080Ti on air.
    Sound Cardonboard?
    MonitorIAsus PA329Q 4k 32"
    Storage #1samsung SSD 960 EVO 250 GB. M2 nvme
    Storage #2Samsung ssd 970 evo 500gb m2 nvme
    CPU CoolerEKwb custom loop
    CaseCorsair Obsidian 900
    Power SupplyCorsair HX1200i 1200w
    Keyboard Logitech G910 orion spark
    Mouse Logitech G502 Proteus core
    OS Win 10
    Network Routerbt infinity super fast.
    Accessory #1 Seagate Barracuda 2 TB HDD
    Accessory #2 Aqeuaro 6xt fan controller
    Accessory #3 Intel Optane 280gb
    Dec 2015
    104
    473
    Question’ two gpu’s in same rig.
    Is there a problem in having a Titan v and a 2080ti in the rig at the same time, ?
    *reason I ask is I would like to bench both cards individually on the same platform but without having to swap the loop to do it.
    I think pcie slots 1 and 2 both work at 16x? So I could just use switches on mobo to disable the one not being tested, to my knowledge I think both slots should give same performance but please correct me if I am wrong!
    It looks also that both cards would use the same driver version.
    Any thoughts on this?
    ROG Guru: Yellow Belt Array F0x135 PC Specs
    F0x135 PC Specs
    MotherboardROG Strix Z370-F
    Processor8700K
    Memory (part number)F4-2400C15Q-32GTZR
    Graphics Card #1Strix 1080Ti
    Graphics Card #2Strix 1080Ti
    MonitorAgon AG352UCG
    Storage #1Samsung 970 Evo NVME 500GB
    Storage #2Samsung 860 Evo 500GB
    CPU CoolerCoolermaster ML240R aRGB
    CaseFractal Meshify C
    Power SupplyInWin C900 Platinum
    Keyboard ROG Claymore
    Mouse Logitech MX Master
    Oct 2017
    131
    Got to make sure the mobo you're going with is going to have enough space. I'm unsure of the clearance with TitanV, but the 2080Ti is 2.75 slot. I wanted to replace one of my 1080Ti's with a 2080Ti, but it won't fit in this z370-F setup. The x2 1080Ti's are already kissing with a 2.5 slot clearance.
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    I'm not as certain that both x16 slots would give identical performance.
    One of them is simply closer to the CPU than the other. It has shorter physical and electrical lengths. Which might translate into lower signal losses or latencies. So I expect that ASUS may have hardwired or firmcoded this slot in a more preferential way ... after all, multi-GPU setups usually put most of the load on the primary GPU anyhow.
    But then again ... you can use PCIe extenders and risers, apparently with surprising lengths, and still have little measurable loss in actual performance.
    The most comprehensive way to answer this question would be to test both cards, then swap and test again ... lol, the answer would be interesting but this approach sort of defeats the reason you even ask the question.
    [/Korth]
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Yes, I have done the same thing with different model cards
    Rob W. PC Specs
    Sound Cardonboard?
    OS Win 10
    Dec 2015
    104
    473
    Both will have EK water blocks , Titan on water is single slot, 2080ti should be reduced to that as well, it’s the stock coolers that boost there size, as to the case**airflow and space not a problem ( obsidian 900d case) .*
    Rob W. PC Specs
    Sound Cardonboard?
    OS Win 10
    Dec 2015
    104
    473
    Quote Originally Posted by Korth View Post
    that’s what my concern was Korth, wether there would be degradation between slots.
    Still as I’m waiting for the Titan to be repaired and I haven’t got the 2080ti yet so it’s all a bit hypothetical.
    I agree it would be interesting to swap them between slots ( a lot of work ) to compare but was hoping to avoide that scenario,
    Still you have aroused my interest now so I will probably try it just to see!*
  7. #7
    Korth PC Specs
    MonitorASUS PG278Q
    Korth's Avatar
    Mar 2015
    152
    2,719
    For reference, I submit Linus's experiment ... the TL;DR summary is that he plugged extenders into extenders (including some "janky old" extenders of dubious reliability) until he hit stability limits and crippling fps losses somewhere around 3.0 metres ... so apparently a few centimeters makes little difference ... but that still doesn't rule out motherboard/firmware optimization choices, I don't think ASUS implements a "T-Topology" counterpart into their PCIe slots.
    [/Korth]
  8. #8
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,801
    For sake of consistency, I would benchmark both of them independently.
  9. #9
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Quote Originally Posted by Silent Scone View Post
    I assumed that was implied
  10. #10
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,859
    Ive dont this. My results were everything defaulted to the slowest card.
