Pg279Q USB 3.0 Hub no Boot
Fabio27
I have a problem with my monitor. if I want use the USB ports of the monitor and I plug eg a USB stick my PC let me not Boot, as soon as I remove the USB stick from the hub he boots.
Since i have a new Mainboard, this Problem comes.
I checked all driver and reinstalled.
thanks.
4 REPLIES 4
Silent_Scone
Super Moderator
You need to correctly configure your boot order from within the UEFI. The system is attempting to boot from the USB pen drive when connected to the monitor hub.
The Boot order is right. I have checked it already. there is no usb in the boot order.
stewart_1
I think Scone hit the nail on the head. Really sounds like your motherboard is still trying to attempt to boot from USB, despite being removed from the Boot order. I would check BIOS settings again and perhaps disable any USB / boot related options, for example USB Legacy support mode.
stewart_1
Another thought... if the USB stick has a small read / write led, it should be possible to see the USB stick become active during the boot sequence. That would confirm the diagnosis.
