ROG Rapture GT-AC5300 - Firmware 3.0.0.4.384.32799 [Report if any issues]
MasterC
Community Admin
Community Admin
New firmware (3.0.0.4.384.32799) was just released for the ROG Rapture GT-AC5300
Manual firmware update download here:
https://dlcdnets.asus.com/pub/ASUS/wireless/GT-AC5300/FW_GT_AC5300_300438432799.zip?_ga=2.155223090....
Please report in this thread if any issues, thanks!
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
122 REPLIES 122
belizejackie
5ghz-2 still not working !! *
75876
75876
random reboots still happening here.
clients with issues to connect to WiFi still happening here.
75876
Have you tried changing the control channel?
75877
75877
The only channel works for me is 165 but it gives me 173.3mbps .. not getting the full speed ...
for me
- 5GHz-1 not working also in guest mode
done 3 times factory reset still same.
(1gbps fiber speed)
Try setting the wireless mode to N/AC mixed. Pick a channel (say 157 for example) Try setting the bandwidth to 40mhz or 80mhz depending on distance to the router. On professional page, turn off roaming assistant. I'm getting a 350mbps connection on 5ghz-2 to a bridge in another building about 75ft away with those settings and bandwidth set to 80mhz.
same..tried all the channels and nothing ... I have been using Asus router since 66u 68u 87u ac5300 and this gt5300 is so stressful ... 😞
*75895
*75895
In the screen shot, it looks like you still have the channel bandwidth set to 20/40/80. Try setting that to 80mhz. Did you "initialize" a factory reset after uploading the new firmware and then redo your settings?
I certainly agree with your last statement! The GT has been out a year and a half and it's still not ready for the market. My rt-ac5300 does pretty much everything better then the GT.
Administrator: *Could you please confirm if this is possible in this FW or not: *Under the VPN Fusion, can you set the VPN as the default connection and then set a device to only access the Internet under the Exception rules? *It seems to me that the opposite works but not this one. *Would appreciate your thoughts.
aka Marin in SNBForums
