Assistance with low frame rates. G74SX
mmeyerj
Greetings,
I require assistance with low frame rates while playing World of Warcraft.
When playing I get around 30 FPS with settings on ultra. This puzzles me as I have the GTX 560M with 3GB of video memory and the 2.2 ghz i7 processor. I was getting a better frame rate with my older machine with an ATI 6570 1GB and a run of the mill AMD 1.8 ghz quad core processor.
I haven't really tried any other games since I've picked up my G74SX. I have, however, ran the Unigine Heaven DX11 Benchmark 2.5 and the results were disappointing (17 FPS).
Is there something I am doing wrong? I will post my DxDiag below.
I appreciate the assistance.
Regards
PS. I am unable to post entire DxDiag. Please let me know if you need more information.
System Information
Time of this report: 2/7/2012, 21:16:26
Machine name: xxxxxxxxx-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTeK Computer Inc.
System Model: G74Sx
BIOS: BIOS Date: 04/27/11 14:06:47 Ver: 04.06.03
Processor: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz (8 CPUs), ~2.2GHz
Memory: 12288MB RAM
Available OS Memory: 12266MB RAM
Page File: 3990MB used, 20538MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 120 DPI (125 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 560M
Manufacturer: NVIDIA
Chip type: GeForce GTX 560M
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1251&SUBSYS_204A1043&REV_A1
Display Memory: 719 MB
Dedicated Memory: 3034 MB
Shared Memory: 1780 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: ASUS VE276
Monitor Id: ACI27F4
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 8.17.0012.8562 (English)
Driver Version: 8.17.12.8562
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 10/15/2011 00:53:00, 15693120 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-5111-11CF-8152-46001FC2C535}
Vendor ID: 0x10DE
Device ID: 0x1251
SubSys ID: 0x204A1043
Revision ID: 0x00A1
Current PC: G74SX-RH71
Current Game(s): World of Warcraft, Kingdoms of Amalur: Reckoning
Current Emotion: Frustrated
11 REPLIES 11
X-ROG
Level 15
Are you running WoW in the native resolution of your G74? If so you will not see a growth in FPS because this is 1920x1080 versus your old notebook which would likely have only been 1366x768: it doubles the pixel demand on every frame rendered.
Also, what graphics settings are you playing WoW at? And are you playing plugged in or on batter?
This is all I can find on the graphics settings - can you let us know what setting is put for each option.
http://wow.joystiq.com/2009/07/20/the-art-of-war-craft-gearing-up-for-pvp/
Thomas
Make sure that the PC is not running in Power Saving mode within control panel under Power Options. Also update the video drivers from the following link: http://www.nvidia.com/Download/index.aspx?lang=en-us
Thomas Jenner
Asus UK
Thank you both for your helpful suggestions.
I was able to up the frame rate by reinstalling the latest nVidia drivers with a clean install. This was done by selecting Custom -> Clean Install during the driver installation.
It's very curious that the manufacturer states that the card has 3GB of video ram but the DxDiag tool only finds 719 MB. According to another post on the Tested.com forum (http://www.tested.com/forums/please-help/7/video-ram-not-correct/11899/?) the card doesn't actually have 3 GB of memory on board and that the majority of it is shared memory. Now it is prudent to point out that the individual assisting in this matter (in the tested.com forum) gets his facts wrong and the solution, in that case, was what Thomas had suggested.
Below is a quote from Asus regarding the nVidia geforce GTX 560m.
"According to the system specs, I see that you have Display Memory: 719 MB, Dedicated Memory: 3034 MB and Shared Memory: 1780 MB.
Which means the dedicated memory for graphics on your system is 3 GB which is advertised. Out of which 719 MB is available on the card itself and the rest 1780 MB is shared form the system memory.
Always while the video memory is calculated, the memory available on the card itself and the shared memory needs to be summed up. This technology of sharing the memory is called Turbo cache technology."
I'm afraid you're reading it wrongly. While some notebook GPUs (expecially CPU-integrated graphics) use systme RAM this one does not. The card does indeed have 3GB dedicated GDDR5 chips in it.
Display Memory indicates actual memory IN USE at that time, while Dedicated Memory is 3034MB (your 3GB). Shared Memory is another term altogether and I THINK it's a modern term for what used to be called the AGP Aperture - basically the amount of system RAM it dedicates for graphics based caching to feed your GPU.
Glad you got this sorted though 😄
Warning though: the latest Nvidia drivers have a bug on 560Ms and S3 states (hibernation). So if you use hibernation the display might not come out of standby. This is why our website still has 267 drivers on it.
kb0sdq
Also on wow I found that disabling the vertical sync in the graphics setting for the game helps with frame rate. I get fps up 140 and 50 on the low side like in Stormwind
I have the G73JH
Hope this helps,
Happy ROG_n
Doug
Alright, so the G73 JH contains a ATI Mobility Radeon HD 5870 1GB, correct?
Would that be better than the Nvidia GeForce GTX 560M 3GB that comes with my G74SX-RH71?
kb0sdq
Yes I have the 5870 gpu, Is it better? I think that is a matter of opinion I like it, it does what I need it to
Also I have done a "Clean install" of Windows I have gotten rid of mostly all of the asus software. I did keep the smart login program I like that. Also I updated my bios to 213 and my vbios to the newer one that is listed on the driver site here on this forum, so I have catalyst 11.12 and I have saphire trixx oc-ing my gpu to 825/1100
Oh yea and I am folding while I play wow.
So yea I like it. You probably just need a driver or maybe try a clean install of windows. does make a difference.
Happy ROG_n
Doug
You know what? I did a clean install of Windows as well but I did two installs (older version and an update) of the nVidia drivers and I was getting around 40 FPS in World of Warcraft. I then did a clean install of the nVidia drivers and got up to 60 FPS.
After disabling the vertical sync (rookie mistake, I know) I am how hitting the maximum FPS limit of 100 FPS.
I've also installed Kingdoms of Amalur and it runs as smooth as glass with the clean install of the video drivers.
On a side note, I'd like to thank everyone for their assistance in this matter. Your generosity is greatly appreciated.
kb0sdq
Cool beans glad you are getting better fps. If ever on bronzebeard aliance feel free to pst me I have a guild and all. Just look for any Dafrickenbest members and ask for Doug.
ciao
Doug
