FPS reading on upper right corner of my monitor screen always...
Jake-from-State
Since DICE did the last update of Battlefield 1 (several months ago), I have the refresh rate listed on my monitor (144) all the time.
How may I remove that? Thx...
4 REPLIES 4
MasterC
Community Admin
Community Admin
Which monitor do you have? The refresh rate will remain 144 unless you change it, or when you enable G-SYNC or Adaptive-Sync/FreeSync.
You can disable it by pressing the GamePlus hotkey on the monitor, and then select FPS counter.
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
I have the Acer 27" XB271HU... G-sync, 144hz, 2560x1440, IPS.
In-game (Battlefield 1) I enter the command to shut that off... does nothing.
... Sorry, that is not our product. Perhaps you another counter software running in the background.
Silent_Scone
Super Moderator
Check that overlay is disabled in GeForce Experience and that no other monitoring tools are active, Rivatuner for instance.
