09-21-2018 03:03 AM - last edited on 03-06-2024 08:06 PM by ROGBot
09-21-2018 04:01 AM
09-21-2018 04:05 AM
Silent Scone wrote:
Given the visual artifacts, the issue appears to be with the GPU.
1. Make sure you are not running any form of overclock on the card
2. Reseat the GPU, perhaps using a different slot if possible.
09-22-2018 01:36 AM
marcelmaria wrote:
The card has not been overclocked. Have the card purely for water and the looks.
I have already removed the card from my system and put it back again. Unfortunately this did not help. Other lock is unfortunately not possible.
RMA ?
09-22-2018 01:40 AM
Silent Scone wrote:
Seems the GPU is faulty, if under warranty then RMA is your only resolution.
09-22-2018 01:31 AM
