Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    ROG Enthusiast Array
    Jan 2017
    38
    Code 0E Load VGA Bios
    I have a Asus X399 extreme mobo with a Titan V GPU and 1200W EVGA P PSU.
    Works great, no issue
    Just purchased a 2nd GPU, Nvidia RTX 2080 and want to have a 2nd GPU running on my rig
    However, when I install the 2nd GPU and boot, I always get a Code OE error and can't even get into BIOS
    What I tried
    1- Clearing CMOS
    2- Booting again with just the TitanV in PCIE slot 1 to confirm everything still works
    3- Booting with ONLY my new RTX 2080 in PCIE slot 3 to confirm it boots (yes)
    4- Swapping the power card to GPU's
    My best guess is that I need to change something in my BIOS in order to boot with a 2nd GPU
    Does anyone have any suggestions?
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    MotherboardASUS x99 sabertooth & x299 Rampage VI Apex
    Processori7-5930k & i9-9940x
    Memory (part number)Trident-Z 3200C14 & Trident-Z 3600C16 both Samsung B-Dies
    Graphics Card #1EVGA 1080ti FTW3 water block & Titan Xp copper water block
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Coolerx99 2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads enclosed and filtered on top
    Power SupplyEVGA 1000P2 & EVGA 1200P2
    Keyboard Logitech G910 Orion Spectrum & Logitech G710+
    Mouse 2-Red dragon Perdition
    OS Win-7 & win-10 pro on both systems Win-7 everyday os
    Accessory #1 Heatkiller 4 Pro copper plexi/Optimus Foundation copper plexi
    Accessory #2 Mayhems Biocide and Inhibitor with distilled water
    Accessory #3 Mayhems 3/8-5/8" clear soft tubing
    ThrashZone's Avatar
    Oct 2017
    23
    363
    Tried with just the 2080 installed in the top pci-e slot ?
    Would be nice to list all of your hardware, power supply/.....
    Jan 2017
    38
    Will try poking around the BIOS to see if there is something that might help.
    Someone with similar issue
    https://www.cnet.com/forums/discussi...gpu-installed/
    May 2018
    31
    Hi Asus reps, the current bios for Zenith Extreme is not compatible with operating a RTX 2080 in a multiple card configuration.
    This also means an SLI configuration of two RTX 2080's will also fail to boot.
    ROG Junior Member Array
    Feb 2015
    3
    Someone mentioned a beta BIOS on demand
    Quote Originally Posted by Squall Leonhart View Post
    Are older BIOS versions working, so could a rollback help? Or a BETA maybe?
    I'm in the same shoes with single card boot as the only option ...
    ROG Guru: Yellow Belt Array Cory29 PC Specs
    Cory29 PC Specs
    MotherboardROG Zenith extreme x399
    Processor1950x
    Memory (part number)G Skill F4-3200C16-8GTZ - 64gb
    Graphics Card #1GIGABYTE GeForce GTX 980 Ti WF
    Monitorcintiq 22hd touch
    Storage #1Sam SSD 850 EVO 1TB
    CPU Coolerxspc block - D5 - 3x120 slim rad
    CaseView 71 (doesn't fit board)
    Power SupplyEVGA supernova 1000G3
    Keyboard K95
    Aug 2017
    131
    *reviewers a couple of weeks ago pre launch were complaining about thread-ripper and this card some said they could get it to boot only if they disabled cores that the card only used 2 cores when trying to bench*
    -- they said that there was going to be a day one firmware update or driver ...
    sounds like amd or asus needs to update something on the board too for this card
    sucks I was gonna jump to a 2080ti guess ill wait a few months to see what happens
  7. #7
    ROG Member Array
    Sep 2018
    11
    18
    asus rtx2080s no boot,error code oe load vga bios
    i am also having trouble with 2 rtx2080s no boot ,works with one ,also tried one rtx2080 and one gtx980 it booted ,
    same board asus zenith extreme x399
  8. #8
    ROG Member Array
    Oct 2018
    I'm having the same problem. I've posted in the ZENITH EXTREME BETA UEFI 0901 thread too. Not sure where the best place to get attention on this issue is. Only response I've had so far is from elmor on overclock.net forums. I see the issue raised on multiple platforms:
    - Reddit
    - overclock.net
    - ROG forums
    - Nvidia forums
    - EVGA forums
  9. #9
    ROG Member Array
    Sep 2018
    11
    18
    what about the people who have full water cooling ,when they drain all there water install these cards,only to find out it does not work
    its simply not good enough,its there flag ship board ,its the first asus board i have ever purchased ,after this it may be my last ,
    PLEASE ASUS SORT THIS PROBLEM OUT SOON,there is no direct line to speak to someone ,i feel like we are being ignored
  10. #10
    ROG Member Array
    Oct 2018
    @Harley2000 It's no excuse on ASUS'Ss part but you can use the dip switches to disable PCIE slots for the immediate term. If it comes to replacing the board it's a whole other matter.
    You're quite right. Support has been a disaster considering this is a flagship product.
Tags for this Thread
