Results 1 to 3 of 3
    New ROGer Array
    Sep 2018
    4
    Post Power Brick + Surge Protector Spark = Fried PC?
    I have a ROG G20AJ, which as you might know, comes with a 230W power adapter/brick.*
    Yesterday I took my computer to my friend’s house and just tried plugging the power brick into my surge protector (which I have no business using, seeing as it’s literally from 1993). As soon as I plugged the brick in, the wall outlet sparked and popped. I unplugged the brick (and my TV) from the surge protector, and then unplugged the surge protector from the wall. The outlet itself has some black spots, clearly from a rush of electricity. The prongs on the surge protector are the same way. I tested my TV and power brick in a new surge protector in a different outlet and both are getting power.*
    My question is, did my power brick get a surge of electricity in it? Like, is there electricity built up in it that will fry my PC if I plug the brick into it? Or am I worrying over nothing? Also, how can I test if my power brick is fine (i.e. not overloaded) before plugging it into my PC?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    294
    7,410
    You won't have electricity "built up" to worry about as it's not really possible for your brick to store an excess of electricity. Likely it just wouldn't work if it got fried. There is a very remote chance that the brick failed in such a way that it will provide unstable voltage to the machine. In that case you might have issues. If the machine crashes or powers off don't keep trying.
    You could try using a multi-meter on the connector while the brick is plugged in, but if it's just damaged and not dead it might not show issues until there is an actual load on it.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    Apparently I gotta spread some rep around before you get any more @xeromist, haha.
    If the power adapter is a somewhat bulky heavy dense thing then it probably contains a transformer - meaning that it is somewhat resistant to momentary voltage surges/spikes and somewhat better at mitigating any surges/spikes it passes downstream (to its output switching/regulator circuits).
    Probably just a flash/arc and a whif of ozone and a little bit of blackening but no real internal damage (aside from a minor heart attack and some de-rating on any internal MOV components, if there are any).
    Definitely time for a new surge protector or power bar (which evidently has a failed or saturated MOV within it), lol.
    I would use a DMM to test the wall receptacle output voltage, it's probably okay but if the voltage variations are too noisy or too frequent then it might be best to plug your machine into some other mains circuit or even upgrade your breakers/wiring.
    A battery UPS is never a bad investment, especially with so much reliance on SSDs these days, I never operate (or recommend operating) a desktop without a UPS anymore. (Laptops and mobile devices are okay, their built-in battery is functionally the same thing.)
    [/Korth]
Tags for this Thread
