Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Guru: Yellow Belt Array feedmeink PC Specs
    feedmeink PC Specs
    MotherboardX299 Rampage vi extreme
    ProcessorI9 7980xe
    Memory (part number)Corsair vengeance lpx 4000mhz 32gb (2x16gb)
    Graphics Card #1Ek waterblock vega 56
    Storage #1Samsung 970pro 1tb m.2
    CPU CoolerEk full monoblock
    CaseLian li pc-011 dynamic
    Power SupplyEvga 1200 watt platinum
    OS Windows 10
    Jul 2018
    69
    187
    2nd watercool build lian li pc-011 dynamic
    My first watercool build was in the corsair 570x. I learned a lot. The i9 7980xe runs extremely hot. Decided to upgrade to high end fans and a new case. This is 3 360mm radiators. 2 are 47mm thick and one is 30mm thick in the back of the case. I'm currently waiting for a smaller res, due to the loss of space from the size of these radiators. I love this case and am going for low temps, high overclock. In 3 days I will have the rest built and will update. I'm done with rgb fans. Just not my thing anymore. I will post pictures of my delid as well. It is my first time. The ihs square is larger than the die, but I'm assuming will be fine since it is only making contact with the die. If you have any advice on the delid I'm all ears. Used liquid electric tape on the compontents.
    feedmeink PC Specs
    ProcessorI9 7980xe
    OS Windows 10
    Jul 2018
    69
    187
    List of components :
    *i9 7980xe delid
    *rampage vi extreme mobo full monoblock
    *overclocked vega56 waterblock
    *32gig 4,000mhz corsair vengeance lpx
    *2 360mm radiators (47mm thick)
    *1 360mm radiator (30mm thick)
    *9 noctua pmw 3,000rpm fans
    *1tb samsung 970 m.2 drive
    *8tb 3.5 storage drive
    feedmeink PC Specs
    ProcessorI9 7980xe
    OS Windows 10
    Jul 2018
    69
    187
    It wont let me upload the photo from my phone
    feedmeink PC Specs
    ProcessorI9 7980xe
    OS Windows 10
    Jul 2018
    69
    187
    feedmeink PC Specs
    ProcessorI9 7980xe
    OS Windows 10
    Jul 2018
    69
    187
    This one is the delid https://postimg.cc/gnJBQFN5
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Looking forward to some photo's, I like the looks of that case
    It seems to me that you may have a little to much LM, but it is difficult to tell from photo's. wait for more feedback from others
  7. #7
    feedmeink PC Specs
    ProcessorI9 7980xe
    OS Windows 10
    Jul 2018
    69
    187
    Quote Originally Posted by Menthol View Post
    Honestly I used the smallest drop I could. I used the flash for this photo (if that makes a difference). Do you think the ihs having a larger square cause a problem? (Assuming that I used the proper amount of LM. Which I feel confident about)
  8. #8
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Yes probably the flash, no that shouldn't hurt, the CPU's I have delided, I put tape around the die and on the IHS leaving the die area exposed, when spreading the LM the excess ends up on the tape which is removed before mounting IHS. I don't think it makes any difference just the instructions I followed the first time and didn't see any reason to change.
    Since you covered components any excess shouldn't hurt.
  9. #9
    feedmeink PC Specs
    ProcessorI9 7980xe
    OS Windows 10
    Jul 2018
    69
    187
    Good idea with the tape. Next time around I will do that for sure!
  10. #10
    feedmeink PC Specs
    ProcessorI9 7980xe
    OS Windows 10
    Jul 2018
    69
    187
    Here's what I have so far
