Results 1 to 9 of 9
09-26-2018 12:06 PM #1
- Join Date
- Sep 2018
- Reputation
- 10
- Posts
- 4
ROG Strix Fusion 700 Bluetooth Issues
ROG Strix Fusion 700 -
So with cable on the STRIX X99 - it's AMAZING, the sound are to real!
Going Bluetooth on the PC - sound turn into something bad and horrible!
I've bought ASUS USB-BT400 Bluetooth USB-adapter, maybe that would help, but no, the sound are realy bad, sounds like an old rip off 90p on youtube.
All comps are updated to latest.
Also, the sound are perfect when connected to my Huawei phone.
:/ Brand new, and it gives this sound on wireless. :/Last edited by Herofiles; 09-26-2018 at 12:18 PM.
10-16-2018 01:08 AM #2
hanz00 PC Specs Laptop (Model) Asus ROG G74SX Motherboard Maximus IX Hero Processor Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz Memory (part number) G.SKILL TridentZ RGB Series 32GB (4 x 8GB) DDR4 3200 (F4-3200C14D-32GTZR) Graphics Card #1 ROG STRIX GTX1080TI 011G Monitor ROG PG279Q Storage #1 Samsung SSD 960 Pro M.2 NVMe 1TB Storage #2 Seagate 2TB FireCuda SSHD 7200 RPM SATA 6Gb/s 64MB Cache CPU Cooler Swiftech H320X2 AIO Case NZXT Noctis 450 ROG Edition Power Supply EVGA Supernova 850 P2 Keyboard ROG Claymore Mouse ROG Chakram Headset Strix Fusion 700 Mouse Pad ROG Sheath Headset/Speakers H/K Aura Studio OS Windows 10 Pro 64-bit Accessory #1 Samsung SSD 860 EVO 1 TB (x2)
- Join Date
- Dec 2011
- Reputation
- 10
- Posts
- 18
10-16-2018 05:56 AM #3
Can you please provide more information pertaining to what you connected the Fusion 700 to? (Before you purchased the BT dongle)
The USB-BT400 may not be a better fit since it is Bluetooth 4.0 and the Fusion 700 supports 4.2.
If the sound is fine when connected to your Huawei phone, then Bluetooth functionality should fine on your Fusion 700.
You should definitely still have high-quality sound via BT, but keep in mind that since it's a wireless connection - the audio will compressed, the DAC is not utilized, and Hi-Res is only available via USB.Last edited by MasterC@ROG; 10-18-2018 at 06:01 AM.
02-14-2019 12:21 PM #4
g_rowell PC Specs Motherboard ASUS ROG Maximus IX Hero Motherboard Processor Intel Core i7 7700K Memory (part number) G.Skill Trident Z RGB F4-3200C16Q-32GTZR 32GB (4x8GB) DDR4 Graphics Card #1 ROG-POSEIDON-GTX1080TI-P11G-GAMING Graphics Card #2 ROG-POSEIDON-GTX1080TI-P11G-GAMING Graphics Card #3 ASUS ROG SLI HB Bridge - 3 Slot Sound Card ROG Strix Magnus Monitor ASUS ROG PG278Q x 2 Storage #1 Team T-Force Delta RGB 2.5in SATA SSD 250GB Black x 2 Storage #2 Western Digital WD Black 2TB x2 CPU Cooler ASUS ROG RYUJIN 240 Case IN WIN 805i Infinity ROG certified Case Power Supply ASUS ROG-THOR-1200P Keyboard ASUS ROG Strix Flare Mechanical RGB Keyboard - Cherry Red Mouse ASUS ROG Chakram RGB wireless mouse with Qi Headset ASUS ROG Strix Fusion 700 Gaming Headset Mouse Pad ASUS ROG Balteus Qi Headset/Speakers Audioengine A2+ , Audioengine S8 & Audioengine D1 OS Windows 10 Pro 64bit Network Router ASUS ROG Rapture GT-AC5300 x2 Accessory #1 ROG Aura Terminal Accessory #2 ASUS ROG Throne QI Accessory #3 AX3000 Dual Band PCI-E WiFi PCE-AX58BT
- Join Date
- Aug 2015
- Reputation
- 10
- Posts
- 42
Hi all Any update to a fix for this , i just replaced my ROG Strix Fusion 700 for one issue, now i have second issue, the same issue as above it sounds terrible in Bluetooth mode but works perfectly in USB mode
the interesting things i found When Bluetooth to PC sound is terrible , Via USB sound is great when i connect to a mobile phone and play sound also sound it Great, i'm thinking its something windows is doing but would need support to resolve
any ideas would be appreciatedLast edited by g_rowell; 02-14-2019 at 01:42 PM.
02-16-2019 02:03 AM #5
- Join Date
- Aug 2015
- Reputation
- 10
- Posts
- 42
Hi All My issue is now resolved sound is now perfect
Try this if your still having the issue still i was able to fix it by throwing out my CSR Harmony Wireless chip-set USB Bluetooth (ORICO)
Ask windows to uninstall driver then install new adapter
the one i have used as the replacement is the Edimax EW-7611ULB N150 Wi-Fi & Bluetooth 4.0 Nano USB Adapter
which looks like it may be using a realtek chip-set
https://www.edimax.com/edimax/mercha...50/ew-7611ulb/
04-14-2019 10:14 PM #6
- Join Date
- Apr 2019
- Reputation
- 10
- Posts
- 2
Hello i got the same problem when i try to watch youtube video sound is terrible but when i watch https://www.tranimeizle.net/ this video sound is great. 7+1 sound terrible also for youtube. What can be reason for this stuation?
04-17-2019 05:32 PM #7
- Join Date
- Apr 2019
- Reputation
- 10
- Posts
- 1
Bluetooh issue
My GL552VW ROG laptop is having a build in 4.0 bluetooth. is this the reason i'm having bad sound quality?
07-16-2019 01:49 PM #8
- Join Date
- Jul 2019
- Reputation
- 10
- Posts
- 1
Same problem - Bad sound quality BT paired with laptop
I have asus rog strix scar II laptop with W10 / automatic updates and have the same problem. When i pair my Fusion 700 headphones with bluetooth sound quality takes me back to 96kpbs winamp days. When using USB sound quality is fine and also no problem when using bluetooth connection with my nokia phone. What would help?
11-15-2020 04:43 PM #9
- Join Date
- Oct 2019
- Reputation
- 10
- Posts
- 1
need some help with pairing those headphones with tp-link archer tx3000e. my pc doesnt find headphones
