Results 1 to 2 of 2
    New ROGer Array
    Sep 2018
    2
    Post Issues Since Latest Audio Driver Update!!! Please Help
    Hi all,
    recently updated to Audio Drive Build 6.0.1.8480, and since then both Sonic Radar 3 and Sonic Studio 3 are not loading. When try to open they show an error "software cannot be opened. update audio driver first." Icons have disappeared from taskbar too.
    MOBO is ROG STRIX B350-F GAMING, Windows 10 Home, latest build.
    Update was done via ASUS EZ Update, and then also tried a clean install.
    Anyone else facing similar issues?
    Also, could someone tell me the version of Audio Driver which comes with the MOBO CD. I seem to have misplaced mine, if no solution found I may have to revert back to that version.
    Thanks in advance!
    New ROGer Array
    Sep 2018
    2
    Fixed it!
    ROG Support sent an attachment with latest driver, file size was larger compared to the one on their website. Clean install, Windows Update (A-Volute) and all seems to be working as expected.
