Results 1 to 8 of 8
    ROG Junior Member Array djona12 PC Specs
    djona12 PC Specs
    Laptop (Model)MSI GS70 2QE-056FR Stealth Pro
    MotherboardAsus ROG CROSSHAIR VI HERO
    ProcessorAMD Ryzen 7 1700
    Memory (part number)G.Skill F4-3200C16D-16GTZRX
    Graphics Card #1KFA2 GeForce GTX 1080 Ti EXOC Black
    MonitorAOC Agon AG352UCG
    Storage #1Samsung SSD 960 EVO Nvme M.2 1TB
    Storage #2Seagate ST2000DM006 Barracuda 2TB
    CPU CoolerCustom loop (Black Ice Nemesis GTS 240 & 360 radiators / EKWB fullcover blocks)
    CaseCorsair Crystal Series 570X RGB
    Power SupplyEVGA SuperNOVA 850 G3
    Keyboard Corsair STRAFE RGB - Cherry MX Silent
    Mouse Asus ROG Spatha
    Headset Logitech G933 Artemis Spectrum
    Mouse Pad Aorus Thunder P3 XL
    Headset/Speakers Logitech Z533
    OS Windows 10 Pro
    Network RouterTechnicolor TC7210.V
    Accessory #1 6 x SP120 RGB LED High Performance Fans
    Accessory #2 Custom m.2 wifi/bluetooth card
    Feb 2017
    3
    ROG Spatha Battery replacement
    Hello,
    I've owned the Spatha for almost two years now and aside a few software issues (like the rest of the power users i assume), i'm quite pleased with it.
    Unfortunately, for a few month the battery has been dying on me, at first not holding charge and now not charging at all...
    Is it possible to order an official battery from the warranty service without sending the mouse back in RMA ?
    Sending the mouse would be difficult as it has become one of the main piece of my workspace (bless macros) and getting away from it for too long would really hurt the productivity so i'd like to find a solution that leaves the mouse at my desk
    Thanks,
    djona12
    Administrator Array MasterC@ROG's Avatar
    Aug 2014
    110
    1,642
    I know the process is straightforward and easy for you to do yourself. Unfortunately the mouse will still have to go through the RMA process, so that we can make sure both the mouse and battery are working as they should after it is installed.
    ROG Member Array Joshwk22's Avatar
    Jul 2013
    6
    Quote Originally Posted by MasterC@ASUS View Post
    Mine is out of warranty, what should I do? The RMA process doesn't have an option for repairs outside warranty. Thank you
    ROG Guru: Orange Belt Array Dicehunter PC Specs
    Dicehunter PC Specs
    MotherboardAsus ROG Crosshair Hero VIII X570
    ProcessorAMD Ryzen 3950X PBO
    Memory (part number)Corsair Vengeance LPX Black- 32GB - 3600MHz *4x8GB*
    Graphics Card #1XFX 5700XT Thicc III Ultra 8GB @ 2050/1750
    Graphics Card #3Corsair Commander Pro
    Graphics Card #4Corsair RGB Fan LED Hub x 2
    Sound CardFiio K5 Pro
    MonitorAsus ROG XG35VQ Ultrawide 100Hz
    Storage #1WD Black SN750 1TB + WD Heatsink
    Storage #2Western Digital Caviar Black 6TB + 6TB
    CPU CoolerCorsair A500 + 2 x Corsair HDRGB 120mm Fans
    CaseCorsair 680 X - Black + 8 x Corsair HDRGB 120/140mm Fans
    Power SupplyCorsair RMi 1000w + Black Cablemod Kit
    Keyboard Asus ROG "Claymore 100%" RGB Cherry MX Blue + Black PBT Double Shot Keycaps
    Headset Beyerdynamic DT770+DT990 Pro 250 Ohm
    Mouse Pad Asus ROG Scabbard
    OS Windows 10 - Professional 64 Bit Edition
    Accessory #1 Audio Technica AT2020XLR + Focusrite Scarlett Solo 3rd Gen
    Accessory #2 Corsair ST100 x 2
    Accessory #3 Asus ROG Spotlight
    Dicehunter's Avatar
    Aug 2011
    20
    372
    My Spatha is also out of Warranty, How do I continue using the wireless functionality if the battery requires charging every 2 hours ? I do not mind buying another battery or even a few for long term use but not having the option to buy a battery is basically telling your customers to not buy your products anymore as you don't support them.
    Jul 2013
    6
    Decided to open the mouse yesterday to see what battery model was in there, and noticed the battery was VERY swollen (not good). This thing is squishy like bubble gum and probably was going to fail any day now. Disposed of it properly, but now my mouse only works with the cable. I found another battery on amazon that has the same voltage and mah. Problem is that it's slightly wider and wouldn't fit in the tray without me cutting away the plastic housing (which I prefer not to do). With that said I haven't found the correct sized battery anywhere else.
    Note: I got the mouse in 2017, but I definitely expected it to work more than 2 years. My 5 year old logitech MX master i got for work is 5 years old still holds a good charge.
    amazon battery link: https://www.amazon.com/gp/product/B0...PL1YID8X&psc=1
    Attachment 80697
    Jul 2013
    6
    So i ordered that battery from Amazon and it didn't work. Nothing happened at first, but I noticed the polarities were reversed (black and red wire), I changed it and the mouse started to work with the battery, but once the battery drained it wouldn't charge back up again. It seems the little PCB and chips on the battery are different, and thus didn't charge. I called ASUS, and told them my problem. They basically said that since it was out of warranty, they could charge me a "diagnostic fee", then charge me the shipping (to and from), plus another parts and labor fee to get this resolved. All-in-all I'm not going to do this, as the cost and trouble are higher than just buying a new one. With that said I'm switching brands, as I've had nothing but issues with ASUS. I own several of their products, including the ROG Horus Gk2000 RGB keyboard, that had 1 software update since launch and was nearly abandoned from the start. Also the support from ASUS is a pain, they should look at corsair, steel series and others to see how it's done (especially since are "premium" products).
  7. #7
    Dicehunter PC Specs
    Dicehunter's Avatar
    Aug 2011
    20
    372
    Quote Originally Posted by Joshwk22 View Post
    I ended up buying a Logitech MX Master 2s, The latest of the MX Master series of mice, Long story short it's amazing, Battery lasts weeks on a single 3 hour charge, Literally, No firmware issues, No tracking issues, Feels a lot smoother and precise than the Spatha and the customer service rep told me I can get the battery replaced if it ever goes bad.
    @Asus you need to step your game up, Releasing a mouse that you cannot replace the battery on and that runs out of charge really quickly, Even with all lights off, Is not acceptable especially considering this is one of the most expensive mice on the market.
  8. #8
    ROG Guru: White Belt Array 28BeersLater PC Specs
    MotherboardRampage V Extreme
    Processori7-5930K
    Graphics Card #1ROG Strix Vega 64
    Sound CardBose External USB
    MonitorLG IPS235 x3
    Storage #1Kingston HyperX Predator 480GB
    Storage #2Corsair Neutron XT Series 960GB
    CPU CoolerEK RVE Monoblock
    CaseCorsair 900D
    Power SupplyCorsair AX1200
    Keyboard Logitech K800
    Mouse ROG Spatha
    Headset/Speakers Bose Companion 5
    OS Windows 10 Pro
    Network RouterROG Rapture GT-AC5300
    Jun 2016
    75
    As above I was an early Spatha adopter. I know there was a firmware issue that prevented the mouse from sleeping and utterly drained the battery, which was decreasing the battery life, and as above my mouse went from diminished battery life to none.
    Is there any news on a replacement battery? I expected a mouse of this price to last a lot longer!
    Gotterdammerung: Rampage V Extreme | Intel I7-5930K | 32GB Corsair Dominator 2666 | EVGA GTX 980 SC x3
    Kingston HyperX Predator 480GB | Corsair Neutron XT 960GB | Corsair AX1200 | Corsair 900D | EK RVE Monoblock | EK 980 GTX Blocks
    GOOSE: STRIX Z390I Gaming | Intel i9-9900KF | 32GB Vengeance RGB 3200 | STRIX Vega 64 | Samsung 970 EVO Plus 1TB x2
    Corsair SF 750 | Phanteks Evolv Shift X | EK Z390I Monoblock | EK Strix Vega 64 GPU Block
Tags for this Thread
