Results 1 to 5 of 5
    ROG Member Array
    Jan 2015
    23
    My monitor wakes up randomly when PC oid shut down.
    My Asus VK278Q monitor keeps randomly waking up with the PC shut down (OFF).
    I added an AMD R9 390 video card and it still does it.
    I use HDMI cable.
    I checked the website and no firmware for the monitor, nor any driver.
    I also replaced the HDMI cable.
    Any clues why this would happen?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    344
    8,018
    Try unplugging the HDMI completely. If it still does it with no input then the display itself has a malfunction.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Member Array
    Jan 2015
    23
    It still does it with no cables attached (except power).
    Could it be some setting in the menus?
    I reset the settings in the monitor in the menus and it still does it.
    Any ideas how to fix it at all?
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    344
    8,018
    Typically the only reason a monitor should wake besides receiving a signal is if buttons are pressed. Are these capacitive buttons? I guess if you have anything bunched up around the monitor, sticky notes on the bezel, etc you might want to clear the area to see if anything is disturbing the buttons. Unfortunately this may be an internal sensing circuit getting tripped when it shouldn't. I have a TV that would turn on & off on its own. The fix was replacing a bad circuit board.
    ROG Member Array
    Jan 2015
    23
    Bummer. This is an old monitor, but has always done it. I thought maybe it was the old PC that was doing it (z68, i3-2100T, iGPU). I had sold it several years ago and got it back recently. I added a GPU and it continued, then tried your suggestions and it still continues.
    I guess I just need to power it off after use, like the previous owner did. It's so old, not sure it's worth fixing (2010).
    Thanks for your help.
