g75vw problem with led of keyboard
lancelot494
hello, I have an asus g75vw, this model I bought 2d, but I broke the motherboard ..., I decided to buy a 3d motherboard and the monitor I changed it to 3d (with its cable too),
everything works fine, except one thing .. the Led lighting of the keyboard no work,
my question is if there are two different versions of keyboards for 3d and 2d ?, and if the 2d battery is compatible with version 3d,. I have installed the asus ATK controllers but the LED lighting does not work in any way (the FN key works, can move audio level audio up and down, activate/disable wifi etc, but illumination no work..) can someone help me, thanks
iXPert12
When attaching the top keyboard panel, please check that all cables are attached to motherboard correctly.
navis995
Level 11
i know exactly what it is and how to fix it!
i had the same problem.
just follow this
https://rog.asus.com/forum/showthread.php?105903-How-to-fix-backlight-that-doesnt-work-after-new-bio...
Asus Rog G750JZ
Screen: 1920x1080 17.3'
CPU: Intel® Core™ i7-4700HQ (3.4Ghz @ -70mV)
GPU: GeForce GTX 880M 4GB (OC +125Mhz Core, +600Mhz Memory @ 1.062V)
RAM: Samsung 32GB 1600MHz
Storage #1: Samsung Evo 840 250GB
Storage #2: Samsung Evo 850 500GB
Storage #3: Seagate Barracuda 2TB
Storage #4: Samsung Evo 128GB MicroSD
