Results 1 to 4 of 4
    ROG Junior Member Array
    Aug 2015
    3
    Unhappy Maximus 8 Impact + H115i PRO Help
    Hey Im trying to build my first PC and trying to set this cooler up thats supposed to be compatible. The issues seems that the motherboard doesnt have a usb 2.0 to plug it in only and 20 prong 3.0. Im trying to figure out in what ways to go about to getting this thing plugged in. And if I cant, what other CPU coolers can I use since I dont have a usb 2.0 on the mother board to plug in. Much thanks if you can help me with this headache.
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,801
    Hi, the Impact 8 has a great deal of performance packed into a small space, so some features inevitably don’t make the cut. You can use header converters such as these:
    Aug 2015
    3
    Quote Originally Posted by Silent Scone@ASUS View Post
    But the thing is I dont wanna get ride of my 3.0 usb either. I was hoping to find a way to keep it and have the usb 2.0
    ROG Guru: Yellow Belt Array pndiode PC Specs
    pndiode PC Specs
    Laptop (Model)Lenovo
    MotherboardROG Maximus IX Extreme, 1301
    ProcessorI7-7700K
    Memory (part number)G-Skill F4-3600C17Q-16GVK
    Graphics Card #1ROG GTX 980 MATRIX-GTX980-P-4GD5 Bykski Water N-AS98ROG-X Full Cover
    Graphics Card #2ROG GTX 980 MATRIX-GTX980-P-4GD5 Bykski Water N-AS98ROG-X Full Cover
    Graphics Card #3GPU Tweak II 1.9.7.1 works, no GPU volt monitor since Version 2.8.3.0, shows in LN2 mode only
    MonitorSAMSUNG S22D300HY (2 ea)
    Storage #1WD Black SN750 1TB
    Storage #2WD Blue 4TB (4 ea)
    CPU CoolerEK Kit L360
    CaseINWIN 707
    Power SupplyThermalTake Toughpower 1200W
    Keyboard Cerberus
    Mouse Logitech MX Master S2
    Headset ROG Strix Fusion 300
    Mouse Pad Generic
    Headset/Speakers Bose Companion 3 Series II
    OS Win 10 Pro 1903
    Network RouterGeneric
    Accessory #1 ASUS Fan Extension Card
    Accessory #2 ASUS Blu-Ray Drive (BW-16D1HT)
    Accessory #3 ROG 10GB Express
    Jan 2016
    130
    This might work, but you will have to do some cable splicing to shorten the cable and route it through one of your PCIE slots to one of the 3.0 USB headers on the back of your motherboard.
    StarTech Mini USB Cable - A to Right Angle Mini B or StarTech Mini USB Cable - A to Left Angle Mini B.
    I have no idea what the connection of the Corsair Link USB cable to the pump looks like, but contact Corsair Support for verification and confirm if this work around works.
    The only thing you need the USB cable for is to change the color of the led.
    https://www.reddit.com/r/Corsair/com..._without_link/
Tags for this Thread
