Results 1 to 10 of 20
10-12-2018 07:23 PM #1
- Join Date
- Oct 2013
- Reputation
- 10
- Posts
- 37
Maximus XI Extreme - DIMM.2 slot question
Hello
I am interested in purchasing one of the new MXIE motherboards when they become available, and am somewhat confused by the inclusion of the "DIMM.2" used as an expansion slot for NVME based M.2 SSDs.
It seems the main rationale behind it is the physical connections means the mounted SSDs sit in the path of the airflow in a case to assist in thermal performance. But there are also claims that this connector is somehow wired to the PCIE controller onboard the CPU itself, like the PCIE 1/2 slots used for graphics cards.
Does this mean that when using the DIMM.2 slot for 2 NVME SSDs, the bandwidth available to graphics cards will be limited? My understanding is the Intel CPUs themselves only have a maximum of 16 PCIE lanes available, so presumably only 8 are available for graphics if 8 are in use by the DIMM.2-connected devices?
There seems to be remarkably little information about how this feature would actually work. Any input would be appreciated!
Thanks
10-12-2018 09:52 PM #2
The DIMM.2 slot is wired to 8x PCIE lanes. The CPU will allow for 1x16, 2x8, 1x8+2x4 configurations. So with two NVME drives connected to DIMM.2 the GPU will run at x8, correct. The performance difference between the two lane speeds is negliable, sometimes none existent , in fact.
10-12-2018 11:59 PM #3
Mr. Fox PC Specs Laptop (Model) - NA - Motherboard EVGA Z490 Dark K|NGP|N Processor i9-10900KF @ 5.6GHz Memory (part number) 16GB Patriot Viper DDR4-4000 @ 4600 Graphics Card #1 EVGA RTX 3090 K|NGP|N Monitor Predator XB271HU 2560x1440 165Hz Storage #1 512GB 970 EVO x 2 (OS Boot Drives) Storage #2 960GB Samung Enterprise NVMe SSD x 2 | 2TB HDD CPU Cooler MO_RA 360 Radiator +1/2 HP Water Chiller Case Praxis WetBench Power Supply EVGA SuperNOVA P2 1600W Keyboard Corsair K95 RGB Mouse SteelSeries Sensei Wireless Headset Skullcandy Crusher Wireless S6CRW Mouse Pad Black Anodized Aluminum Headset/Speakers Logitech Z506 5.1 Speaker System OS W10 Ent LTSC 2019 / W7 Ultimate (Dual Boot) Accessory #1 Hailea HC-500A 1/2HP~790Watt Water Chiller
- Join Date
- May 2018
- Reputation
- 41
- Posts
- 127
The reduction in speed is relevant to the chipset and CPU. If you go with X299 the DIMM.2 will not slow down the PCIe speed to 8x with the right CPU because you will have ample PCIe lanes.
With my setup, I have dual DIMM.2 cards and a total of 4 NVMe drives (2 on each DIMM.2) and the GPU still runs at full bore 16x.WRAITH // EVGA Z490 Dark K|NGP|N | Core i9-10900KF @ 5.6GHz | Optimus Signature Water Block on Bare Die | EVGA RTX 3090 K|NGP|N | 16GB Patriot Viper 4 Blackout DDR4 @ 4600 | EVGA SuperNOVA 1600 P2 | Hailea HC-500A (1/2HP~790W) Chiller | MO-RA3 360 Pro Radiator | Dual XSPC Photon 270 | Windows 7 Ultimate > Windows 10 Enterprise LTSC 2019 > Windows 10 Enterprise 2004 Cancer Edition > Linux Mint
10-13-2018 12:12 AM #4
Hopper64 PC Specs Motherboard Asus R6EE Bios 0070 Processor i9 10900X @ 5.0 1.37V VCore Memory (part number) GSkill F4-4000C18Q2-64GTZR Graphics Card #1 EVGA 3090 FTW Ultra/EKWB Quantum Vector Nickel/Plexi Sound Card Creative SB AE7 Monitor Asus ROG PG349Q Storage #1 Intel 905p M.2 360G CPU Cooler EKWB Magnitude RGB and Quantum Kinetic D5 Case Phanteks Enthoo Elite Power Supply Corsair AX1600i Keyboard Asus Strix Flare Mouse Asus ROG Gladius II Origin OS Windows 10 64
- Join Date
- Nov 2012
- Reputation
- 57
- Posts
- 2,265
I was looking for a definitive answer to this lane allocation question on the M11E too. If I use the dimm.2 with one SSD that still might decrease the graphics card to 8x, but is there a bios setting to switch the dimm.2 to the PCH? The top and bottom slots on the board are not connected to the CPU so I could use an adapter in the very top slot and run the SSD via the PCH. Anyone know for sure?
10-14-2018 11:18 PM #5
- Join Date
- Oct 2013
- Reputation
- 10
- Posts
- 37
Thanks for the responses guys, that explains it.
I echo Hopper64's sentiment though - is there a way to have these slots run through the PCH instead?
10-25-2018 05:41 PM #6
- Join Date
- Oct 2013
- Reputation
- 10
- Posts
- 37
Sorry to bump this thread, but any chance an Asus rep could get back to us on the above query?
Thanks!
11-08-2018 10:55 AM #7
- Join Date
- Aug 2018
- Reputation
- 11
- Posts
- 28
Dear Mr. Fox!
Would you please tell me, that configuration do you use?
I'm confused a bit and would appreciate any help. I would like to build a new rig, using at least 2 pieces of 970 EVO M.2. This SSD has a maximum read speed of 3500 MB/s. If I buy Maximus XI Formula or Extreme +9900K, I can't use the two M.2 drives in a PCIe slot (with a PCIe card or DIMM.2), becouse I will not want to have X8 bandwidth for my graphics card instead of X16 (I know, the difference is marginal, but with new RTX cards there actually will be some FPS difference). If I insert the two M.2 SSDs into the onboard slots, than I will be bottlenecked by the chipset, becouse DMI bus will allow only 3,9 GB*s in total. So, another choice could be an Asus Rampage Deluxe II + 9900X. In this case, I would have enough PCIe lanes for all my M.2 cards to run at full speed + X16 for my video card. But X processors haveless boost speeds than for example 9900K (5Ghz on two cores or overclocked to all). So perhaps X processors are not as effective for games as 9900K (?). But here comes another dilemma. If I use two M.2 SSDs on the board slots and not raiding them, would the DMI bus speed really matter that much in reality? For example when copying files from one drive to another?
Thanks!
12-06-2018 03:41 AM #8
MorePower PC Specs Motherboard Asus Maximus XI Extreme Processor Intel i9 9900K Memory (part number) G.Skill Trident Z RGB 32GB Graphics Card #1 ASUS Strix 2080 Ti OC Monitor LG UltraGear 34GK950G Storage #1 Samsung 970 PRO NVMe M.2 Storage #2 Samsung 860 PRO SSD x 2 CPU Cooler ASUS ROG Ryuo 240 Case Phanteks Evolv X Power Supply Seasonic Prime Ultra Titanium 850W Keyboard Corsair K70 RGB MK.2 Low Profile Mouse Corsair M65 RGB ELITE Headset/Speakers Kanto YU4 + Sub8 OS Windows 10 Pro
- Join Date
- Oct 2012
- Reputation
- 10
- Posts
- 76
12-06-2018 07:02 AM #9
- Join Date
- May 2018
- Reputation
- 41
- Posts
- 127
Sorry for the delayed reply. You may be overthinking the process too much. Prior to my current setup I had a Maximus X Hero (WIFI-AC) motherbord with an 8700K CPU and 1080 Ti. I had both of the M.2 slots populated with a 960 Pro and my 1080 Ti ran at 16x with no issues.
12-07-2018 10:44 AM #10
btrach144 PC Specs Motherboard ASUS Maximus XII Extreme Processor Intel i9 10900K @ 5.1 GHz Memory (part number) 32 GB G.Skill DDR4 4000MHz C17 Graphics Card #1 EVGA 2080Ti FTW3 Hydro Copper Monitor ASUS PG27UQ Storage #1 x2 Samsung 970 Pro 1 TB in RAID 0 Storage #2 Samsung EVO 850 1 TB CPU Cooler Custom EK loop Case Corsair 750D Power Supply ROG THOR 1,200W Keyboard Logitech G915 Mouse Logitech G903 PowerPlay Headset Logitech G935 Mouse Pad Logitech Powerplay Headset/Speakers Logitech Z905 5.1 surround OS Windows 10 (2004) Network Router ASUS AX11000
- Join Date
- Jun 2014
- Reputation
- 10
- Posts
- 146
