Results 1 to 5 of 5
    New ROGer Array videodj PC Specs
    videodj PC Specs
    MotherboardAsus Maximus X Hero
    ProcessorIntel i7 8700k @ 4.7Ghz
    Memory (part number)32GB (2x16GB) Corsair DDR4 Vengeance RGB Pro, PC4-24000 (3000)
    Graphics Card #1Asus ROG Strix RX VEGA 64 OC edition 8GB HBM2
    Sound CardSound Blaster Zx
    MonitorAcer XF270HUA 27" IPS, Acer Nitro VG271UP 27" IPS
    Storage #1Samsung Evo 970 Plus 500Gb
    Storage #2Samsung Evo 970 1Tb
    CPU CoolerCorsair Hydro H115i PRO RGB
    CaseCorsair Graphite 780T White
    Power Supply850W Corsair RM850i PSU
    Keyboard Corsair Strafe RGB MK.2
    Mouse Corsair M65 Pro RGB, Logitech Performance MX Mouse (Darkfield)
    Headset Arctis Pro Wireless (White)
    Mouse Pad Corsair MM800 RGB
    Headset/Speakers Logitech Z906 5.1 Speakers
    OS Windows 10 Pro 64bit
    Network RouterNetgear NightHawk
    Accessory #1 Corsair Commander Pro
    Accessory #2 Corsair Lighting Node Pro RGB
    Accessory #3 Gigabyte WB1733D-I 1733Mbps PCI Express WiFi Adapter
    videodj's Avatar
    Sep 2018
    4
    Maximus X Hero - USB 3.0 issue
    Hi
    I have just finished my new build, however I have an issue with the rear usb 3.0 ports. I have a usb 3.0 enclosure attached to one of the ports and the transfer speeds are only between 20 and 30 MB/s. If I attach the same enclosure to my front usb ports, which are connected to the motherboard header, I get 120 MB/s as expected and as I saw on my previous P8P67 Deluxe. I have updated the drivers, but I'm at a loss as to the poor performance of the rear ports.
    Asus Maximus X Hero
    Corsair Vengenance Pro RGB - 32GB
    i7 8700K
    Asus Strix Vega 64
    Corsair RMi 850
    Corsair H115i Pro RGB
    Samsung Evo 970 Nvme M2
    Samsung Evo 860
    Has anyone else had similar issues or any ideas on how to resolve?
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,373
    Hi videodj
    Welcome to the ROG forum.
    First two things I'd try is...
    1) Update the chipset driver
    2) Update the bios
    Get these at the ASUS Support Center, select your operating system.
    https://www.asus.com/us/Motherboards...Desk_Download/
    videodj PC Specs
    videodj's Avatar
    Sep 2018
    4
    Thanks, I've already updated the Bios to the latest version.
    I'll try the chipset drivers later when I get home from work. I usually only install them if there are exclamation marks in device manager
    ROG Guru: Orange Belt Array geneo PC Specs
    geneo PC Specs
    MotherboardMaximus XII Hero
    ProcessorIntel 1070k @ 5.1Ghz
    Memory (part number)64 GB G.Skill TridentZ RGB 3200/CL14 @ 3600
    Graphics Card #1Asus ROG Strix 2070 Super A8G
    MonitorEIZO Coloredge CG2730 and Viewsonic QHD displays
    Storage #1Samsung 512 GB 960 Pro
    Storage #21TB 850 x 1 TB 860 EVO RAID0, 6 TB WDC Black HDD
    CPU CoolerNoctua NH-D15 Chromax
    CaseFractal Design R4 w/ tempered glass
    Power Supply750W Seasonic Prime Ultra Titanium
    Keyboard CM Quickfire Rapid TKL
    Mouse Logitech G305
    Headset Bose
    Headset/Speakers Vanatoo T1, ML Dynamo 300
    OS Windows 10 Pro X64
    geneo's Avatar
    Feb 2014
    37
    408
    When you plug it in the back, go to the device manager -> disk drives, find the drive, look at the properties -> policies and make sure it is set to "Better Performance"
    videodj PC Specs
    videodj's Avatar
    Sep 2018
    4
    So I enable better performance while the drive was attached to the front ports and speeds went upto ~200Mb, which is good. I updated the chipset drivers and rebooted and plugged the drive into the rear port again and speeds are now the same as the front ports.
    Thanks for your help.
