Results 1 to 2 of 2
    ROG Junior Member Array
    Feb 2015
    1
    Asus Zenith Extreme problems with HyperX Predator RGB 32GB 2933Mhz RAM
    Hey all
    I am using the latest BIOS and Aura software on my board. Anything other than the default setting puts the DIMMs out of sync. When i click static colour only the 2 DIMMs to the right of the socket light up. i have them in a quad channel configuration
    The product code for the RAM is:HX429C15PB3AK4/32
    Thanks
    ROG Member Array
    Dec 2016
    21
    Aura makes me a lot of troubles as well. My Enermax liquid cooler RGB are often not turning on. So far the solution I have is to turn off the computer completly, powering off the power supply or unplugging it from the wall, wait few seconds and turn back on.
    Hope that help for you too.
