Results 1 to 2 of 2
    davidpai
    Guest
    M4A89GTD PRO Power Supply Question
    I have been out of game for far to long I see that now. Anyway, I just purchased a M4A89GTD Pro motherboard and I was assuming I could use my old power supply with it.
    I have a Antec SL400 power supply, its a 400W with 20 pin + 4 pin connectors. The new motherboard now that I am doing my research is a 24 pin + 8 pin connector.
    The obvious....I need a new power supply. The bad and ugly...its Christmas Eve and I am trying to get this system up for the morning so my kids can tinker on it tomorrow on WoW.
    Am I totally screwed or can I get by with it for a couple of days?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,887
    Yes, the 4 pin will work fine. You really only need the 8 pin EPS for demanding setups. If you don't overclock or run a lot of devices off of the mobo you will be fine.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
Similar Threads
  1. M4A89GTD PRO PCI-E Boot Support ?
    By bkarankar in forum Other Series Motherboards
    Last Post: 07-13-2011, 01:58 AM
  2. AC Power Supply Problem
    By thumper64 in forum ROG Gaming Notebooks
    Last Post: 12-30-2010, 03:28 AM
  3. M4A89GTD PRO/USB3 IGPU
    By Scott in forum Other Series Motherboards
    Last Post: 12-24-2010, 09:06 AM
  4. ATX Power Connectors
    By zfrenchpig in forum Other Series Motherboards
    Last Post: 11-18-2010, 11:37 PM
  5. R3E Question...
    By gvii in forum Other Series Motherboards
    Last Post: 11-01-2010, 09:01 PM
