Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    ROG Member Array levye PC Specs
    levye PC Specs
    MotherboardAsus Rog Strix Z370-E
    Processori7 - 8700K
    Memory (part number)Corsair 32GB Vengeance LPX DDR4 3000 Mhz
    Graphics Card #1Asus Rog Strix GTX 1080 Ti
    MonitorLG 32GK850G-B - 32" LED Monitor - QHD G-Sync
    Storage #1Samsung 860 EVO SSD X 2 (RAID 0)
    CPU CoolerBe Quite! Dark Rock Pro 4
    CaseFractal Define R6 Blackout TG USB-C
    Power SupplyEVGA Supernova G3 1000W
    Keyboard Das Keyboard
    Accessory #1 Be Quite Silent Wings 3 140mm PWM
    Accessory #2 Be Quite Silent Wings 3 140mm PWM
    Accessory #3 Be Quite Silent Wings 3 140mm PWM
    levye's Avatar
    Sep 2018
    8
    PC wont power on after initial start and BIOS check
    I have built a brand new PC and when i first hit the power button, everything went fine. I have accessed BIOS setup and checked options.
    After that, I have powered off/restarted PC couple of times to check BIOS again. (No OS installed yet)
    Next day, when i wanted to enter BIOS again, I hit the Power button and nothing happened. PC gives no response. (does not turn on, no fan spinning, nothing.) However lights on motherboard and also PWD_LED are on. Lights are also glowing / fading.
    [COMPONENTS]
    - Intel i7 8700K CPU
    - Asus Rog Strix Z370-E Gaming
    - Asus Rog Strix GTX 1080 Ti 11G GPU
    - CORSAIR - VENGEANCE LPX Series 3000Mhz DDR4 16GB x 2 RAM
    - Be Quite Dark Rock Pro 4 CPU cooler
    - EVGA Supernova 1000G3 PSU
    - Samsung SSD 850 EVO 500MB + 500MB
    - Fractal Define R6 TG USB-C Case
    - 3 X 140mm Be Quite PWM Chassis Fan
    - LG 32GK850g 32" LED Monitor
    [STATUS]
    1- I have moved motherboard from case to cardboard to see if motherboard shorting to the case. So I have removed all unnecessary components (such as SSDs, additional RAM, Graphics Card etc) and only left CPU, CPU cooler, RAM. I have connected it to the PSU with 2 cables (1 for motherboard and 1 for CPU) Please see attached pictures.
    1- When i connect PSU cable i can see that motherboard lights are on. (glowing RGB) I also see a standby orange color led also on. (PWR_LED)
    2- I dont see any Q-Leds on (boot,vga,vram,cpu)
    3- I cant smell any burn from motherboard.
    4-After initial setup, i was able to enter BIOS and checked couple of things there, Lastly, i entered RAID setting to set RAID0 but I haven't completed it.
    Then i have restarted the PC and there was a message on screen related to RAID and SSD s but i am not %100 sure what it was. Then i turned it off until next day.
    5- I was working sometimes on carpet and also using some magnetic screwdriver on motherboard. But i was able to run pc couple of times after and haven't touched to PC after.
    [THINGS I DID]
    1- I reconnected motherboard power cable and cpu power cable.
    2- I cleared CMOS both by using 2-pin CLRTC and removing battery separately.
    3- I have checked PSU cables in case any of them loose
    4- I connected RESET_SW to POWER_SW to see if the problem is with front power button. So i have tried to turn on PC by reset button but again no progress.
    [QUESTIONS]
    1- What does it mean if lights are on , on my motherboard but not powering on?
    2- When PC is connected to PSU, which LEDs should be on (on motherboard and case) and what color?
    3- Considering all these, is it possible that my motherboard is somehow dead?
    4- Is there any way to check if my motherboard is dead ?
    5- Can static electric can cause my motherboard or other components dead?
    6- Only thing left is CPU and cooler. Is it possible that if motherboard is somehow does not recognize the cooler so that it wont turn the PC on?
    Thanks
    --Emre
Name:	WhatsApp Image 2018-10-16 at 21.59.06.jpg
Name:	WhatsApp Image 2018-10-16 at 21.59.06 (2).jpg
Name:	WhatsApp Image 2018-10-16 at 21.59.06 (1).jpg
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    170
    2,193
    Disconnect the CPU cooler, remove the CPU and then reseat it.
    Reattach the cooler whilst checking for even mounting pressure, don't overtighten. See if you're able to get the system to POST.
    ROG Guru: Green Belt Array Rob W. PC Specs
    Rob W. PC Specs
    MotherboardRog Asus Rampage vi extreme
    ProcessorIntel i9-7980x Oc 4.6ghz 24/7
    Memory (part number)64 gb GSkill 3600mhz (8x8) 15,15,15,35
    Graphics Card #1nvidia Titan V + ekwb custom loop
    Graphics Card #2nvidia RTX 2080Ti on air.
    Sound Cardonboard?
    MonitorIAsus PA329Q 4k 32"
    Storage #1samsung SSD 960 EVO 250 GB. M2 nvme
    Storage #2Samsung ssd 970 evo 500gb m2 nvme
    CPU CoolerEKwb custom loop
    CaseCorsair Obsidian 900
    Power SupplyCorsair HX1200i 1200w
    Keyboard Logitech G910 orion spark
    Mouse Logitech G502 Proteus core
    OS Win 10
    Network Routerbt infinity super fast.
    Accessory #1 Seagate Barracuda 2 TB HDD
    Accessory #2 Aqeuaro 6xt fan controller
    Accessory #3 Intel Optane 280gb
    Dec 2015
    104
    501
    Hi levye.
    Whilst checking the above, it might be worth checking your psu, they can cause similar problems, test as below
    *https://www.evga.com/support/faq/afm...px?faqid=59582
    levye PC Specs
    Processori7 - 8700K
    levye's Avatar
    Sep 2018
    8
    Quote Originally Posted by Silent Scone@ASUS View Post
    I need to reattach it as well however I have applied thermal grizzly conductonaut between CPU and cooler so i am not sure about how to remove it as i need to re apply it. So still searching about what is the best way to remove it. The thing is cooler is kind of big and heavy so when i install the mobo , due to its weight, it might be pulled toward bottom because of gravity. But it is made for it right so it shouldn't be a problem.
    Mar 2016
    170
    2,193
    Quote Originally Posted by levye View Post
    Should be easy enough with minimal resistance. The weight won't be the issue, but you could simply try loosening it and see if this helps, too. Definitely reseat it when you have time, though. Also try with one memory module in slot A2.
    levye PC Specs
    Processori7 - 8700K
    levye's Avatar
    Sep 2018
    8
    Quote Originally Posted by Rob W. View Post
    Hi levye.
    When i have run the test with EVGA Detection tool, it seems PSU works fine as fan is spinning on it.
    However,
    1- When i connect 24 pin power cable to the mobo and set the rocker switch on PSU to ON position, this time fan is not spinning.
    Should it also spin when i connect PSU to the mobo and turn on PSU?
    2-After connecting PSU to mobo, I did shorting power SW pins with a screwdriver in order to simulate power button on case, nothing happened so i have tried couple of times. Then something happened such that,
    - PSU fan starts to spin, CPU fans also try to start then all stops and i see a click sound from PSU then tries to start again. It all takes couple of
    second each time. After click sound, PSU again tries to start mobo and cpu but after CPU fans spin 1-2 seconds , stops again. So I have just
    powered off the PSU as i didn't want to destroy anything.
    - Couple of minutes later, I have again tried to touch PWR SW pins with screwdriver but nothing happened this time. No response.
    I am using IKEA screwdriver with a hard plastic handler. Should i use any specific kind of screwdriver to do it?
    Thanks for all responses. I appreciate all.
  7. #7
    ROG Member Array Outlawone PC Specs
    Outlawone PC Specs
    MotherboardROG MAX X wifi
    Processor8700K
    Memory (part number)G-SKULL TRIDENT 16 GIG 3200
    Graphics Card #1EVGA 1080 COPPER
    MonitorASUS
    Storage #1MME2 960 EVE 500 GB
    Storage #2SSD SAMSUNGE 850 PRO
    CPU CoolerRAYSTORM
    CaseEVGA D9
    Power SupplyEVGA 1200 PLATINUM
    Keyboard MADCATS STRIKE 7
    Mouse G 900
    Headset AFTERGLOW WIRELESS
    Headset/Speakers 7.1 tHX
    OS WINDOWS 1O 64 BIT
    Outlawone's Avatar
    Jun 2018
    11
    6
    ok I had the almost the same problem so not sure but this it what happened to me and I have the same power supply I was trying everything and thought for sure it was the board I even had the board replaced it ended up being that I used the 24 pin power cord from the newer evga 850 power cord they looked the same but for some reason it wouldn't work. So if you have another connector try that.
  8. #8
    levye PC Specs
    Processori7 - 8700K
    levye's Avatar
    Sep 2018
    8
    Quote Originally Posted by Outlawone View Post
    Unfortunately i don't have another cable to test.
  9. #9
    ROG Guru: Green Belt Array Phillyflyer's Avatar
    Mar 2012
    30
    536
    Levye....please check the back of the board for trace damage that may have occurred during the initial install....I say this because the board did post at one time without issue...and now no post whatsoever...leaves me to believe that the board may have come in contact with the standoffs and caused a short and possible damage thereafter....the cpu...socket pins should be fine as well as cooler since you did have board initially post
    Asus ROG Maximus XI EXTREME
    Intel i7 9900K OC'D @ 5.2 GHZ @ 1.345V (1.296V LOAD) LLC 6 PRIME 95 STABLE 8 HRS
    XSPC RX360 Rad (6)Scythe Gentle Typhoon 1850 RPM Fans In Push/Pull @ 1500 RPMS
    Swiftech Drive II / Swiftech MCP35X Pump
    Enermax Platimax 1200 Watt Power Supply
    32GB G.Skill F4-3866C18Q-32GTZR 3866 MHZ CL18 1.35V (OC 4266MHZ 17-18-18-41-2T @1.45V)
    MSI GTX 1070 SEA HAWK EK X SLI WITH ASUS HB RGB
    (5)Samsung 840 Pro 128 GB In Raid 0
    (2) WD 1TB Black Edition
    Corsair 900 D
  10. #10
    Outlawone PC Specs
    Processor8700K
    MonitorASUS
    CPU CoolerRAYSTORM
    CaseEVGA D9
    Mouse G 900
    Outlawone's Avatar
    Jun 2018
    11
    6
    hey just wondering by that pic you have there is the ram in right slot 1 and 2 like that just wondering .
Tags for this Thread
