Results 1 to 9 of 9
    ROG Member Array
    Jun 2016
    8
    Maximus XI Code Z390 will not fit my ATX case
    Trying to assemble my new system, and I cannot get the M/B to align on my Silverstone RL06 case. The shield is preventing the M/B from aligning over the risers since it doesn't stick out the cutout. How do I remove the Code's shield so it cat fit the cutout? This is really frustrating me, cannot see how to resolve this.
    Paul
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    20
    1,470
    Maybe you don't do something right.
    Should fit, be careful, I always when need to aligne motherboard pay attention to avoid scratching back side on spacers.
    Did you get small metal part. You should install him first, but on pictures looks like he is pre-installed. That small part need to click and and stay, but if they install him on motherboard...
    Easy.
    I try to find video clip of Code XI.
    ROG Member Array
    Jun 2016
    8
    I was able to force the board against the opening, and although I ended up chewing the threads of the screws against the i/o side of the M/B holes, I got it locked down. Seems Asus went for a "don't allow any gap ever under any circumstances" rather than leaving even a fraction of a millimeter of space to align holes. I never could figure out how to remove the shield...I think I would have to remove armor and who knows what else. I had to remove my MB again because the dumb RL06 case rear cutout for the CPU was not large enough to mount the cooler backing screws...grrr.
    Paul
    New ROGer Array
    Oct 2018
    1
    I am having similar issues with a XI Hero fitting into a Corsair Obsidian RGB case. When I drop it on the alignment peg, the bottom 6 holes line up perfect. Top 3 holes are off 1-2 mm toward the front of the case...I can't figure it out....
    ROG Enthusiast Array willburstyle06 PC Specs
    MotherboardASUS MAXIMUS VIII HERO
    Processori7-6700k OC 4.7GHz
    Memory (part number)G.SKILL TridentZ RGB 32GB DDR4 3600MHz
    Graphics Card #1EVGA 1080 Ti FTW3
    Graphics Card #2EVGA 1080 Ti FTW3
    MonitorAsus PG278QR
    Storage #1Samsung 960 Pro NVMe M.2 1TB
    Storage #2Samsung 860 Evo 2TB
    CPU CoolerKraken X62
    CaseNZXT H440 RAZER
    Power SupplyCorsair HX1000i
    Keyboard BLACKWIDOW CHROMA
    Mouse DEATHADDER ELITE
    Headset KRAKEN 7.1 CHROMA
    Mouse Pad RAZER GIGANTUS ELITE
    OS Windows10
    willburstyle06's Avatar
    Sep 2013
    46
    Quote Originally Posted by Haywood74 View Post
    Did you ever figure out a solution? I am having the same issue fitting the XI Hero into my H440 case. The IO shield is preventing the top 3 holes from aligning
    CPU - i7-6700k 4.7GHz
    MOBO -Asus Maximus VIII Hero
    RAM - 32GB G.Skill TRIDENTZ RGB DDR4//3600 MHz
    GPU - EVGA 1080 Ti FTW3 SLI
    SSD - Samsung 960 Pro M.2 NVMe 1TB //Boot
    SSD - Samsung 860 Evo 2TB
    HDD - WD BLACK 3TB 7200RPM// Media//Gaming
    PSU - Corsair HX1000i
    CASE - NZXT RAZER H440
    CPUCOOLER - Kraken X62
    ROG Member Array
    Nov 2018
    7
    [QUOTE=willburstyle06;743932]Did you ever figure out a solution? I am having the same issue fitting the XI Hero into my H440 case. The IO shield is preventing the top 3 holes from aligning[/QUOTE
    I have the same problem but with the 390 series Maximus XI board, see my post @ https://rog.asus.com/forum/showthrea...373#post745373
    I took it to a local computer shop, they tried 5 different ATX cases from InWin, none will fit the z390 board.
    I was advised to return it and buy an MSI instead, the computer shop called it a cheap and poorly manufactured board...
    The only case I was able to successfully install it is in the cheap ass ThermalTake Versa H24 (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1). However, that case has limited space for a 164mm cooler and barely can house a single 120mm watercooler
    ALL ASUS Z390 BOARDS NEED TO BE MANUFACTURER RECALLED!!!!
  7. #7
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    You should be able to push the top of the board against the back of the case to insert the screws, yes it is a tight fit but I have been able to install these boards in Corsair, Lian Li, NZXT cases
  8. #8
    ROG Member Array
    Jun 2016
    8
    Quote Originally Posted by Menthol View Post
    I have deinstalled and reinstalled it a couple of times now. Finding that it is a bit easier if you sort of warp (not a huge flex, just work it) the board from the far side and get the far top right screw in, then sort of mash it all down using the far edge screw to push the panel against the case, then just chew the screws through the other holes.
  9. #9
    New ROGer Array
    Sep 2018
    2
    SOLUTION for these boards
    I was running into the same problem with Maximus XI Hero with the ThermalTake View 37 (view 31 is the same chasis)
    I have the Thermaltake View 71 and I've heard the Coolermaster MasterBox 5 RGB works too and now the motherboard fits NO force needed
    The IO opening has to be the following exactly or a 1/16 bigger on the longer end, my case and its probably with yours is 1/16 of an inch too small, its so slight of a difference that its hard to tell so you HAVE to measure
    The measurements to fit are 6 7/16 inches (long side) 1 3/4 inches for shorter side and you will be fine, I checked the size on the 2 cases I said earlier that work
    All 9 screws line up and NO FORCE needed to fit
