Intel Rapid Storage Tech. driver
sdmf74
Level 11
Well it seems Asus has given up on Z270 as far as driver updates go. Im curious what I should do about Intel Rapid Storage Technology. My current download
from Asus is version 15.9.0.1015 from December 2017, it looks like Intel has released at least 2 versions since then. Im not sure if it would be best to download the newest version 16.7.0.1009 from Intel or if I should remove it all together? I know it can cause slow boot times etc. Is it posible to just install the updated AHCI
driver and not the IRST software? Please give me your expert opinions.
Asus MIXFormula
Intel I7 7700k
Samsung 960 pro m.2 (Samsung NVME 3.0 driver installed)
Samsung 850 pro (Samsung Magician installed)
Samsung 850 evo
WD Black HDD (as external drive)
ASUS Maximus 13 Hero, Intel I9 11900k, EVGA GeForce RTX 3080 FTW3 ULTRA
6 REPLIES 6
Vlada011
I stopped to install him on X99 because my HDD WD Black 2TB sometimes gone after restart.
He was visible in BIOS only not in OS and request to re-plug SATA cable on motherboard.
Culprit was IRST. Microsoft driver default for Windows 10 is ok, same performance, no problems.
This happen to lot of people. I didn't had problems with SATA II HDD before 2-3 years, but when I replace with SATA III problems show up.
Abaidor
Well for everything related to Intel RST you will be hard pressed to find better info than on this thread:
https://www.win-raid.com/t2f23-Intel-RST-RSTe-Drivers-newest-v-WHQL-v-WHQL.html
Read EVERYTHING on the first page carefully there and you will find the latest driver for your platform.
I have INTEL RSTE driver installed on my Rampage VI Windows 10 machine and it works fine. Initially I had also the console installed but since I am not using a RAID array I just have the drivers now and all is working great.
Beware though that downgrading from the RSTE version to RST can cause trouble and render your PC unbootable so choose wisely.
Asus Rampage VI Extreme | i9-7940X | 64GB Trident Z RGB 3600 | Asus Strix 1080Ti OC | Samsung 960 Pro 512GB | WD Gold 10TB | WD Red 4TB X 2 | PSU Corsair AX1500i | Custom Water Loop - RAD MO-RA3 420 Pro | EK Monoblock | Phanteks GPU Block | Heatkiller 200 Tube RES | EK Dual D5 Revo Pumps | 9 X Corsair ML 140 Pro Fans on RAD | | Bitspower Fittings Black Chrome | Cooler Master Cosmos 2 Modded Case | Silent WIngs 3 120mm Intake |
MoKiChU
Level 40
sdmf74 wrote:
Is it posible to just install the updated AHCI driver and not the IRST software? Please give me your expert opinions.
Asus MIXFormula
Intel I7 7700k
Samsung 850 evo
Yes you can install only drivers without software, look here (at SATA) : https://rog.asus.com/forum/showthread.php?105343-DRIVERS-Intel-Chipset-Ethernet-iGPU-MEI-SATA
For my part, I used Intel AHCI drivers only.
Note : Some time ago, I used SAMSUNG NVMe drivers but since I uninstalled them, the Microsoft drivers present in Windows 10 1809 are more efficient.
sdmf74
Level 11
Yeah I was reading that page earlier and trying to figure out why his version #'s dont match up with the drivers on Intels download page, Intels most current driver
is 16.7.0.1009 & he lists v16.7.0.3513 so either Intel pulled that driver for some reason or he is using different version #'s cause he is modifying the drivers. Not
sure which but I went ahead and downloaded the one from Intel. I just installed the full software version & driver but I forgot to test my boot time without an RST driver.
My pc currently boots in just over 19 sec according to task manager, same as with the older Asus IRST driver/software
Abaidor
I am on a different platform and using RSTe so my version is
"64bit Win8-10 Intel RSTe AHCI & RAID drivers v5.5.0.1334 WHQL"
I did not notice any difference in boot time after upgrading with a Samsung 960 Pro NVME (does it even use RST?) but I think my Hard drives perform a bit better. Particularly a Western Digital Gold 10TB I have seems to sustain 220-230 Mb/s writes during backups with Macrium Reflect. It might be my idea though and since I have no measurements before the update I am not 100% sure. The reason I updated was because I was updating several other stuff as part of my maintenance cycle.
sdmf74
Level 11
Intel states that IRST is compatible with NVME but im not sure if it has any effect on boot times
