Maximus XI Code M.2 Slots
URASucKaFisH
Hello,
I am putting together a new build with a Maximus XI Code and one Samsung 970 Evo NVMe. On this board there are two M.2 slots but I am a bit confused as to which one to use when only one M.2 drive is utilized. The manual makes it seem like you can use either so I believe going with the first slot would be correct. Would this be the correct configuration to make sure the 970 Evo is running at its maximum speed?
Any information is appreciated.
Thanks
Edit:
I just ran across this page in the manual that shows the first slot is capable of SATA mode as well as the 22110 form factor, but it doesn't specifically say which slot to use with only one M.2 so I am assuming it doesn't really matter as long as the first slot is operating in PCIe mode. Any thoughts?
76526
21 REPLIES 21
Nate152
Hi URASucKaFisH
Welcome to the ROG forum !
Both M.2 slots can run at x4 so you can use either.
Some prefer the 2nd M.2 slot as it's not constrained to the board. There may be a mounting bracket for the 2nd M.2 slot, I'm not 100% sure on that though.
I can't find any pictures but I would think they mount pretty much the same on the Maximus XI boards.
M.2 slot 1
https://www.google.com/search?q=maximus+Xi+M.2+slot+number+2&rlz=1C1CHBF_enUS815US815&tbm=isch&tbo=u...
M.2 slot 2
https://www.google.com/search?q=maximus+XI+M.2+slot+number+2&rlz=1C1CHBF_enUS815US815&tbm=isch&tbo=u...
URASucKaFisH
On the Maximus XI Code both M.2 slots are right by each other, laying flat, and both are under the heat shield. So with that then I guess it wouldn't matter at all in regards to the correct speed.
Nate152
After seeing the manual, as you say it looks like both M.2 ssd's get mounted to the board.
But at any rate the 970 evo is 2280 which both slots support and both slots can run at pcie x4.
URASucKaFisH
Thank you for the information Nate152!
Nate152
URASucKaFisH
I was actually leaning that way myself since it would be closer to the front fans, but not sure if that would really make a difference for temps to be honest.
Nate152
I see the Maximus XI Code comes with an M.2 heatsink, I imagine you install it on the ssd.
URASucKaFisH
Absolutely. It's one large cover that houses both M.2 slots. It has some kind of adhesive on the back that covers each SSD as well.
Nate152
It should help control temps as M.2 ssd's can run hot, plus you say you have fans in the front as intake, I don't see you having any temp issues.
I'm curious of your new build, care to list all your parts including your case and if you're liquid or air cooling ?
