Battery Replacement G750jx
ravi_balireddy
Did anyone got there G750jx battery replaced? Are there any good brands other than the original? Looked for the original one for almost a month but couldn't find it.
I am from India.
navis995
Level 11
You can find them on ebay. Original and generic.
Just type g750 battery and all will fit. They all use same 88Wh and have 5900mAh capacity.
Asus Rog G750JZ
Screen: 1920x1080 17.3'
CPU: Intel® Core™ i7-4700HQ (3.4Ghz @ -70mV)
GPU: GeForce GTX 880M 4GB (OC +125Mhz Core, +600Mhz Memory @ 1.062V)
RAM: Samsung 32GB 1600MHz
Storage #1: Samsung Evo 840 250GB
Storage #2: Samsung Evo 850 500GB
Storage #3: Seagate Barracuda 2TB
Storage #4: Samsung Evo 128GB MicroSD
Darnassus
Status Under Review
Yap, grab any battery with the matching rating, it should be no problem.
Mostly it's when you look for chargers you have to be careful.
https://www.ebay.com/itm/Genuine-A42-G750-Battery-For-ASUS-ROG-G750-G750J-G750JH-G750JM-G750JS-G750J...
And look! Is from Amerikaaa!! ;U
Also may I add that is a bloody good price for a Battery..
its disguisting how cheap it is yeah...
but they don't ship to eu and here in eu the prices are 2x higher for some reason.
i've even seen 4800mAh one going for 70€!
Asus Rog G750JZ
