Hi all, I just bought a RTX2080ti strix, and it works fine except in farcry 5.
Sometimes the textures flicker and if you look at the sky it flashes.
I have tried different drivers 411.63 and 416.34 but the problem always occurs.
Instead in AC Origins and in the benchmarks (Heaven, Firestrike, TimeSpy, etc ..) there is no Artifact or flickering or crashing
of no kind !. Only with Farcry 5 does the problem occur.
here are the links to see the problem:
https://youtu.be/Y3wq0NiuFrMhttps://youtu.be/Lve2CpNWszQIs it my faulty card? I read around that may be the drivers ...
My configuration:
I7 8700K
Maximus X Formula
Asus STRIX RTX2080ti O11G
SSD Samsung 970 pro 512
I asked on the nvidia forum and they answered this:
"We will be releasing a driver soon that will fix flicker during gameplay in Far Cry 5."
"Given you mentioned you only see this issue with Far Cry 5, I think you are seeing the flicker bug. We will be releasing the driver very soon so if it doesn't fix your issue, please let me know."So my RTX2080ti is not bad since the problem of flickering and artifacts is only in Farcry 5?
Thank you so much if you can help me
Francis
