[Strix Scar II] - Cooling Pad Causes FPS Drop Terribly
cumeo
Hi guys, I've found out an awkward situation that whenever I place the laptop over the cooling pad (mine is cooler master), it immediately drops my fps from 8x to 2x randomly and resulting it laggy.
At first, I was though it was the hardware or software issue and I tried to do so many things like clean install windows, re update the BIOS (mine is 304) and finally it turned out that because of the cooling pad I've purchased weeks ago.
Has any of you encountered this?
[UPDATE] - I AM NOT THE ONLY ONE Came to the ASUS Service yesterday and they said that I am not the only one.
14 REPLIES 14
thebiggboss180
maybe cuz of faulty usb cable
I did not plug the cooling pad USB directly to any USB port of the laptop. I plugged it to my Anker Powercore so it is not the case :).
Update: It happens even when I do not plug-in the cooling pad to any power source.
Bharath_98
I am also having a similar problem. Whenever I try to keep my laptop a little bit elevated from my table, I get fps drops. I think the cooling pad is also showing the same problem because of elevation of laptop from table 😕 doesnt make sense though 😞
Same here, even if the cooling pad level fps drop still experienced. That's why when playing games I never use any cooling pad.
Better if Asus have answer on this matter.
I have the same problem too!! I thought is only my laptop. Do you know why ?
I've put this issue in the FAQ here https://rog.asus.com/forum/showthread.php?106660-GL504GS-GM-useful-thread-Troubleshooting-amp-Guide
Long story short - because cooling pad affects hardware cooling algorithms. This is best explanation so far.
But in my case, I am not using any cooling pads. I am just keeping my laptop a little bit elevated from my laptop table using a book or anything. Asus must give a proper response to this.
Nope, not yet. I am hoping that Asus will tell us a solution. I'mma try going to the service center and talking to them.
STRIXTO
i had same issue anyone had solutions?
