10-27-2018 03:23 PM - last edited on 03-06-2024 09:58 PM by ROGBot
10-27-2018 11:48 PM
10-28-2018 12:58 AM
10-28-2018 02:39 AM
10-28-2018 06:46 AM
HiVizMan wrote:
Throttling is happening by the sound of it. What airflow do you have over your VRMs? Place a directional fan at the VRMs and see if that makes a difference. With AIO water cooling there is very little airflow over the other components and heat is not your friend. Stuff is designed to protect your system from real harm. Which is what I am suspecting happened here. But I would need to see your complete BIOS to have a more clear picture.
What changes did you make to your bios?
10-28-2018 07:31 AM
10-28-2018 01:16 PM
HiVizMan wrote:
Cheers for the response mate. Trust me when I say it happens to all of us, Hell I have run my system with the cooler fan header off and pulled my hair out trying to figure out why temps had shot up...
Set LLC to 6 and adjust your power plan in OS to performance.
VDroop is not a bad thing by the way it is a design feature built into CPU's by Intel and does important work.
10-29-2018 03:11 AM
