Results 1 to 2 of 2
    New ROGer Array
    Sep 2018
    1
    Fan Problems Gl703gm
    Hi, I have an ROG gl703gm notebook, i think i have a problem with the fans.
    even if i choose the 'silent mode' and i only surf the internet fan rotate at minimum speed (i think only the cpu fans) , drivers and windows10 are update, what i have to do?
    thanks
    ROG Member Array
    Jun 2018
    14
    Quote Originally Posted by emanuele0095 View Post
    thanks
    What is the problem if the fans runt at min speed? Are the temps high?
