Results 1 to 6 of 6
    ROG Guru: White Belt Array KeksimusMaximus PC Specs
    MotherboardAsus ROG Maximus X Hero
    Processori7-8700k
    Memory (part number)G.Skill Trident Z RGB 3200MHz 2x8GB
    Graphics Card #1EVGA GTX1080Ti FTW3
    MonitorDell s2718dg A04
    Storage #1Crucial MX100 128GB
    Storage #2WD Black 500GB
    CPU CoolerNZXT Kraken X62
    CaseNZXT S340 Elite
    Power SupplySeasonic Prime Gold 650
    Keyboard CoolerMaster Masterkeys L White
    Mouse Tracer Pert TRM-503
    Headset HyperX Cloud I
    OS Windows 10 Pro
    KeksimusMaximus's Avatar
    Oct 2017
    104
    Thumbs up How to fail 101 - Asus and their THOR PSU's - OLED reports only AC Wattage and others
    1. The "power draw monitoring" that's being blown out of proportion on every marketing page of ASUS Is total failure as it reports only and only AC power draw from wall. Sure, its useful, but the reported pooling rate of PSU makes it useless as the load varies heavily during usage, so the OLED value will jump all over the scale. Even 5$ plug in watt-o-meters do better job and offer more functionality.
    - To make it at least a bit useable, the thing that should be reported is BOTH AC power draw and DC power output (the power that goes directly to PC components) and if no, the DC power output should take precedence before AC power draw! Because THAT IS WHAT PEOPLE WANT TO KNOW, DC power measurement is most difficult for user as it would require taking PSU apart and voiding warranty and having accurate reading from PSU would greatly help in benchmarks of GPU's and CPU's.
    - NZXT was able to do it, impement DC power output measurements in their PSU (but they dropped ball on adding AC power draw measurement).
    2. The OLED screen is only on one side, the fan is on top side. This is the most ridiculous thing. Great majority of cases have an air intake at bottom specifically for PSU's and come with PSU shroud. The PSU shroud may or may not have a cutout.
    - the result? You either have to compromise your cooling to make OLED visible through cutout in PSU shroud or at all with fan pointing away from the bottom case intake or.... you wont see the OLED at all having it covered by PSU shroud?
    - a few second of thinking would lead to conclusion, the OLED display should be attached to PSU on separate cable, the OLED should be in some kind of small casing and this way it could be routed away from PSU to be placed anywhere in the case
    Seriously, looking at the recent "releases" (if these can even be called releases, where from "release" it takes several months for product availability) , it seems ASUS is outsourcing product design and market research to low GPA undergraduate interns.
    First the joke of warranty on their new AIO's - 3 years vs 5/6 years of standard in competitors products and now the fail of PSU where most advertised feature is feasible in small percent of use cases...
    Dargus Maximus
    ~Explorer ~Engineer ~Guide
    My Youtube channel - PC modding, streaming, gaming
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    499
    13,571
    It says the display shows "output wattage"
    Where do you get that it shows input?
    I'm heavily sceptical of anything ASUS does outside of motherboards...but this has a 10 year warranty so I'm less dubious about this than their software for instance
    Processori7-8700k
    CaseNZXT S340 Elite
    OS Windows 10 Pro
    Oct 2017
    104
    Quote Originally Posted by Arne Saknussemm View Post
    https://www.kitguru.net/components/p...ed-seasonic/2/
    https://www.kitguru.net/wp-content/u...box_rear-1.jpg
    "Power draw" but its inconclusive if its PSU power draw of components power draw. Even if latter, a total power draw is fairly useless when both 12V, 5V, 3.3V CPU and GPU are bundled together.
    https://www.kitguru.net/components/p...ed-seasonic/3/
    Also, the whole PSU uses a single ACS725T 1-channel current sensor, so for a single chip it would be impossible to measure load on all three power rails - so only AC draw remains.
    Last but not least, final confirmation:
    https://www.kitguru.net/components/p...d-seasonic/12/
    And other sources:
    https://www.tomshardware.com/news/as...ecs,37806.html
    "Both units feature some modifications, since they are equipped with a small OLED screen on their sides, which shows the AC power that the PSU draws from the wall socket. This is our first objection, since this screen is in a barely usable location, and on top of that, it only shows AC watts. "
    The hardware inside is solid, because the design was done by Seasonic based on their Prime Platinum platform but they will be charging for useless features.
    You are beter off saving some money and buying said Seasonic Prime Gold/Platinum Ultra 850/1200W unit.
    Dargus Maximus
    Apr 2012
    499
    13,571
    I got as far as "Thor was the Norse God of War"
    Who knows what else they got wrong...
    It's a Seasonic with bling and some idea of power output (if it's draw that's in direct contradiction to marketing and would be a bit of a no-no...but the jury is out on that for me)...what's not to like...
    Hmmm
    Processori7-8700k
    CaseNZXT S340 Elite
    OS Windows 10 Pro
    Oct 2017
    104
    Hmmm
    The highlighted part on marketing materials "power draw" can apply both to PC components power draw (DC output measurement) and PSU power draw (AC input measurement).
    But internals speak by themselves, it is the AC power draw. The circuit used in the PSU, as per the teardown reviews, is ACS725T which is capable of measuring at most 50A in it's best variant. https://www.allegromicro.com/en/Prod...Cs/ACS725.aspx
    This means, the chip would be capable of measuring only up to 600W of 12V power output, which is nowhere near the rated power output of PSU.
    Its physically impossible for the Asus Thor PSU to measure total power output in its current design and construction.
    Dargus Maximus
    Apr 2012
    499
    13,571
    Well draw it is then...but since it's aimed at the mass consumer market that seems fine to me too.
    You'd need sophisticated metering to provide accurate numbers for all rails which would skyrocket cost. Less than that would be a rough and ready idea, which is what you have...here.
    I fail to see the great fail to be honest
    Having a movable display would have been a better idea...but that's hardly worth getting upset about...still, each to their own.
