Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 50
  1. #11
    ROG Member Array
    May 2015
    U can’t. Chk my post below.
    There are problem with maximus xi 4 dimms slot. Rated as 4400 oc but i can run only 4200 mhz. Need some bios update.
    Unlike 2 dimm motherboard( gene , strix i gaming , up comming apex ) that can run 4600mhz xmp without any effort.
    Meg godlike and so much cheaper gig aorus can run 4500 xmp in one click. A*lot better than maximus xi extreme.
    What wrong with asus? Fix it pls.*
  2. #12
    ROG Member Array
    Nov 2018
    I Have a 16 GB Dual Kit Gskill 4400 cl18 and i Only Manage to be stable on the Hero XI with downclock the Ram to 4000Mhz.
    Its not Maximus its Medimus but better then Lowmus. But for this Premium Category and Premium Prices Point i hopped for more.
    And Yeah the 4400 OC missleaded me to .. its Only with 4 Dimms installed but this Info you can only find on the ASUS Website not on the Mainboard Package or else
    I Really hope that a Bios Update makes as Happy and make the Board from Medimus to Maximus :-)
  3. #13
    ROG Guru: Yellow Belt Array nickolp1974's Avatar
    Feb 2013
    25
    161
    I wouldn't be to hasty guys in wagging the finger at ASUS as anything over 4k is good and not being able to run XMP at 4400+ is more than likely down to your cpu's IMC and not the board. you probably can get it to run, it will just take time tweaking timings and voltages. I can run 4400mhz with ease on my Gene but 4500 is a no go and I should say that's my limit with this cpu and my current cooling.
    There's lots of variables to take into account it ain't just the board!
    i9 9900K, ROG Gene XI, G.Skill 4266 and one big bucket!
  4. #14
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    XMP is a gamble past 3800. I've found I get best results by manual tuning, dropping the clock and lowering the CL so response is even better!
  5. #15
    Dec 2011
    354
    25,742
    I have had no problems getting XMP profiles to work with my Maximus XI Extreme. Booted up with some 8Pack Edition Team Extreem kits (3 off) without any problems. 4600Mhz is big ask for most CPU's. I happen to have a very good IMC on this processor so was not expecting anything else.
  6. #16
    ROG Guru: Blue Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardMaximus Hero XI
    Processor9900k @ 5.1Ghz All Core 1.315v AVX -2
    Memory (part number)Gskill GTZ 4133 C17 32GB (4x8GB)
    Graphics Card #1ROG Strix 2080 TI OC
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 970 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 970 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks Evolv X
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur VOID Pro
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    79
    914
    I can get my Gskill Trident Z 4133 17Q to boot and run stable at 4133 using XP1 on my Hero XI. Above that I can get it to run, but it requires manual tuning. So it's definitely not the motherboard. It really comes down the CPU's IMC, your cooling and how hard you push the CPU clocks.
    I am still surprised how many folks buy expensive top end highly bin clocked RAM thinking it will run just because the board supports it and fail to even consider the CPU's memory controller. We've been dealing with internal memory controllers on CPUs for quite a few years now. I suppose it would be helpful if board makers and RAM kit sellers really underscored that point on their advertising material. Might save some heartache (and likely reduce some sales) . A lot of folks drop big cash on high end binned RAM that they cannot run with a weaker IMC on the CPU.
  7. #17
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,805
    Quote Originally Posted by Stagefire View Post
    There are numerous factors at play at those speeds. You're asking a lot of CPU at that frequency with a 4 DIMM topology layout, this isn't something that is specific to one vendor. If not looking to dial things in manually always consult the QVL.
  8. #18
    Dec 2011
    354
    25,742
    Quote Originally Posted by mdzcpa View Post
    Never a truer word been spoken in some time my friend. I can not stress just how important the IMC of a cpu is. Folks are so used to discussions about a 'good' cpu being one that will do a frequency at a silly low voltage but that is just one part of what the current CPU is all about. IMC is as critical if not more so in todays memory hungry and dependant software.
    Great post mate.
  9. #19
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    161
    7,454
    The four-Dimm Maximus board’s feature a T-Topology trace layout, which is better for fully populated configs. If you run a two-dimm kit on a T-topology motherboard, the maximum stable frequency will be two to three ratios below the maximum rated frequency for four-DIMM kits. This cannot be fixed by a BIOS update. It’s a limitation of T-Topology.
    Even when using four-DIMM kits, I always advise that users subtract at least a few ratios off the maximum memory frequency the board is rated for. There are many variables at play so opting for the maximum frequency isn’t wise if you favour ease of use.
  10. #20
    Apr 2011
    161
    7,454
    Quote Originally Posted by Pun_VI View Post
    Please write a clear post that states which memory kit you are using (list the part number of the memory kit).
