Warranty void when fitting Water Blocks?
Fluke816
Hi all, I am in the middle of a new build and will be using a ASUS PRIME X299-DELUXE, Intel X299 and a ASUS ASUS Dual GeForce RTX 2080 Ti OC. I plan on installing water blocks on the GPU and MB, will my warranty be void if security stickers are removed?
JustinThyme
The stickers on the GPUs no longer apply to warranty work and probably the same on the MB. This was a fairly recent change. They do however reserve the right to refuse service if the failure is a result of the end user or non authorized shop.
Ive just always run them as is out of the box for a week or two first before making any modifications.
kkn
Level 14
only one make that i know of that have that kind of warranty is EVGA on their cards, as long as you put it back to original again when doing an RMA (to EVGA).
