Results 1 to 4 of 4
    New ROGer Array
    Oct 2018
    2
    Reliable battery for G750J?
    Hey everyone,
    I need a replacement battery for my ROG G750J laptop but I'm overwhelmed with all the options. Some are only $35 while others are $150? Amazon's options have some sketchy reviews, NewEgg's options have no reviews at all! There's one on NewEgg that is refurbished ASUS, so I was wondering if that would be a good option? Has anyone bought a replacement battery for this who can recommend one? I would like something that lasts and is reliable. Price is totally negotiable as long as its a good product.
    Thanks.
    ROG Guru: Brown Belt Array Darnassus PC Specs
    Darnassus PC Specs
    Laptop (Model)G752VS -=-=- G750JX
    MotherboardASUSTeK COMPUTER INC. G752VS (U3E1) -=-=- ASUSTeK COMPUTER INC. G750JX (SOCKET 0)
    Processori7 6700HQ @ 2.60GHz -=-=- i7-4700HQ CPU @ 2.40GHz - 3.40GHz
    Memory (part number)2x16gb (M471A2K43BB1-CRC) -=-=- 2x8gb (HMT41GS6AFR8A-PB)
    Graphics Card #1GTX 1070 (8GB) -=-=- GTX 770M (3GB)
    Sound CardRealtek High Definition Audio / NVIDIA High Definition Audio
    MonitorGSync IPS 75HZ -=-=- Chi Mei 60Hz (Overclocked to 85Hz)
    Storage #1Samsung SSD 960 EVO 250GB x2 -=-=- LITEONIT LCS-256M6S
    Storage #2HGST HTS721010A9E630 -=-=- ST1000LM024 HN-M101MBB
    CPU CoolerStock -=-=- Stock
    CaseStock -=-=- Stock
    Power SupplyStock -=-=- Stock
    Keyboard Stock -=-=- Stock
    Mouse Razer Naga Epic 1st Generation
    Headset SPH 2500
    Mouse Pad Razer Goliathus
    OS Winblows 10 Pro -=-=- Winblows 8.1 Pro
    Network RouterCG3000v2
    Darnassus's Avatar
    Dec 2013
    61
    1,651
    You know there's a thread about this exact same question on the top page? ;x
    https://rog.asus.com/forum/showthrea...acement-G750jx
    https://www.ebay.com/itm/Genuine-A42...MAAOSwcN1aYa0K Amerikaaaa
    Just grab one and try it out. You can always do a Battery Report, and compare it to your old one to see if everything's correct. ;x
    Better yet.. grab the battery, and play a Movie on it. The battery should last roughly almost 3-4 hours. If it doesn't simply return it for a refund. ;x
    Don't know how to do a Battery Report?
    Easy. Open Command Prompt as Administrator (Right click)
    Type powercfg /batteryreport and hit Enter.
    It'll tell you where it saved.
    Save a copy somewhere for safe keeping, then do it with the new battery.
    Gosh Blue Lady.. ❤
    JOIN THE ASUS T-SHOOT DISCORD <-- Clicky!
    New ROGer Array
    Oct 2018
    2
    Quote Originally Posted by Darnassus View Post
    Whoops! I should be more vigilant. Thank you!
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,651
    You're welcome. ;x
    Welcome to the Forums, too. And don't forget to use Battery Report on both Batteries. ;p
    Gosh Blue Lady.. ❤
Tags for this Thread
