Results 1 to 10 of 10
    ROG Guru: Brown Belt Array Darnassus PC Specs
    Darnassus PC Specs
    Laptop (Model)G752VS -=-=- G750JX
    MotherboardASUSTeK COMPUTER INC. G752VS (U3E1) -=-=- ASUSTeK COMPUTER INC. G750JX (SOCKET 0)
    Processori7 6700HQ @ 2.60GHz -=-=- i7-4700HQ CPU @ 2.40GHz - 3.40GHz
    Memory (part number)2x16gb (M471A2K43BB1-CRC) -=-=- 2x8gb (HMT41GS6AFR8A-PB)
    Graphics Card #1GTX 1070 (8GB) -=-=- GTX 770M (3GB)
    Sound CardRealtek High Definition Audio / NVIDIA High Definition Audio
    MonitorGSync IPS 75HZ -=-=- Chi Mei 60Hz (Overclocked to 85Hz)
    Storage #1Samsung SSD 960 EVO 250GB x2 -=-=- LITEONIT LCS-256M6S
    Storage #2HGST HTS721010A9E630 -=-=- ST1000LM024 HN-M101MBB
    CPU CoolerStock -=-=- Stock
    CaseStock -=-=- Stock
    Power SupplyStock -=-=- Stock
    Keyboard Stock -=-=- Stock
    Mouse Razer Naga Epic 1st Generation
    Headset SPH 2500
    Mouse Pad Razer Goliathus
    OS Winblows 10 Pro -=-=- Winblows 8.1 Pro
    Network RouterCG3000v2
    Darnassus's Avatar
    Dec 2013
    61
    1,634
    G752 Microphone has weird issues..
    Anyone know issues with the Microphone on the G752 series? Or if there's any Microphone issues with Win10 itself?
    I just recorded a sound that has a steady rise in volume..
    Yet the Microphone picked nothing up until a certain volume, which was quite loud.
    To me this sounds like.. noise cancellation, or some sort of threshold in sensing the voice.. but the problem is, I exclusively use Push to Talk with Steam, Discord, etc..
    I installed the ReakTek driver "Audio_Realtek_CFL_W10_64_V6018443"
    Which apparently isn't for the G752 but it's the best driver that doesn't have the bug where the volume keeps snapping back to 54%.
    Anyone know what to do to fix this silly 'threshold' with the mic's noise pickup?
    Gosh Blue Lady.. ❤
    JOIN THE ASUS T-SHOOT DISCORD <-- Clicky!
    ROG Guru: Orange Belt Array
    Nov 2012
    55
    392
    If you are running Windows 10 version 1809, then I would wait until Microsoft and Realtek work out their problems. Right now there are a number of audio issues with both. Agree 8443 seems to be best for G752VS now.
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,634
    Quote Originally Posted by jdfrench3 View Post
    REALLY!! May I have some.. sauce.. with that tasty information?
    It doesn't suprise me, how annoying though. I was dreading that this be the case and hoped it'd simply be a driver issue or a setting I need to fix.
    Damn.
    Yes I'm on 1809.
    I just wish the G752 had a mouse pad driver for Windows 8.1 I would be using that OS instead of 10.. stupid garbage.
    Gosh Blue Lady.. ❤
    Nov 2012
    55
    392
    Have you checked the Sonic Studio and Sonic Radar programs? They seem to be affected as well.
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,634
    I fresh installed and don't use those.
    So.. sauce? ;d
    Gosh Blue Lady.. ❤
    ROG Member Array
    Jan 2017
    5
    Same issue
    Hello,
    Same weir issue with G752vm. Noise suppression disabled. No solution found !
    It's a disaster for team speaking !!
    I'm tired of spending time to solve drivers issues using tricks and workaround with my Asus.
    Always the same story.
  7. #7
    Nov 2012
    55
    392
    I fixed my G752VSK by installing the Realtek audio software from the eSupport Folder, then updating that software to what I was running before the Windows update.
    Everything returned to normal after this action.
    I find Realtek software version 6018443, my sweat spot.
    Good Luck.
  8. #8
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,634
    Can anyone confirm they have the same problem too and I'm not the only one? I'm beginning to think it's a defective microphone..
    This is me going.. "aaaaaaaaaaaaaaaaaaaaa"
    But this is how it turns out according to the pickup.
    Just don't know what to do at this stage.. thinking of reinstalling Windows LOL
    Gosh Blue Lady.. ❤
  9. #9
    ROG Guru: Green Belt Array haihane PC Specs
    haihane PC Specs
    MotherboardCrosshair V Formula Z
    ProcessorAMD FX 8350
    Memory (part number)Gskill F3-2400C10-8GTX
    Graphics Card #1ASUS HD 6950
    Storage #1WD Velociraptor 1TB
    Storage #2Corsair Neutron GTX 120GB SSD
    CPU CoolerCooler Master Seidon 120XL
    CaseCooler Master Silencio 650
    Power SupplyCorsair HX850
    Keyboard Corsair K70 RGB
    Mouse Logitech G500
    OS Windows 7 X64
    Network RouterLinksys E2500
    haihane's Avatar
    Jul 2013
    106
    609
    LOL.
    let us hear it.
    no siggy, saw stuff that made me sad.
  10. #10
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,634
    Welp it's definitely Realtek and Windows.. just reinstalled Windows, and tested, the moment I put the driver in, the Microphone began screwing up again. Guess I'm forced to run without an audio driver and just go generic.
    Gosh Blue Lady.. ❤
