You'll need to work out the cfm of your fans, to get positive pressure you'll need to have a higher intake cfm. My current setup is 2 fromt 140mm intakes, plus a 120mm at the bottom. Then a 140mm exhaust at the rear and 2 140mm at the top exhausting my H115i Pro.
I debated putting the rad at the front, but didn't want any heat from the rad pusing warm air onto my Vega 64.
For the cooler, mines plugged into the cpu header and can control the fans fine with iCue, on my Maximus X Hero. Can you see the cooler in iCue? Are you able to change the pump speed?
The link below is a small spreadsheet that will calculate the cfm. just enter the fan cfm and number of fans. The speed % is a just an extra. In my setup you can see that my intake cfm is higher, creating positive pressure.
https://www.dropbox.com/s/tkzyly3kkvhue0n/Fans.xlsx?dl=0
