Results 1 to 4 of 4
    New ROGer Array
    Nov 2018
    2
    AUXIP Installation
    Hello everyone,
    I've just built my first PC and am using the ROG Zenith Extreme motherboard. I ran into a glitch so I had to re-install windows. I plugged the USB that came with my motherboard into my case once more to re-install the drivers and utilities on it once more, and this time a program pops up each time I reboot. It is the "AUXIP Installation". If I click "next" there is a paragraph, and at the end of it it says,
    "In order to provide you with better SERVICE, enhance user experience, and continuously discover problems to improve performance, you acknowledge and agree that ASUS may collect your product information, such as product serial number, MAC address, IP address, frequently used software information and the software function usage behavior to obtain customer feedback and to analysis user experience."
    I don't want this program monitoring me/possibly slowing down my computer. Is it possible to delete this program/pop-up, and if so how? Whenever I click "exit" to get out of it, another pop-up comes appears and says,
    "Exit AUXIP Instillation Wizard may lead to specific device inactivated".
    I already registered my motherboard on my first windows instillation, I don't think I have to register again, right? What does this mean "device inactivated"?
    Thanks guys.
    Edit: Or should I just install it? What did you guys do, and what are your thoughts?
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    498
    13,501
    If you go to Task Manager, Startup tab does it show there...so you can disable it from appearing again?
    There is nothing on that pendrive that you need really. Updated versions of chipset driver are available online...
    New ROGer Array
    Nov 2018
    2
    Quote Originally Posted by Arne Saknussemm View Post
    Hey, thanks for trying to help. I ended up just re-installing windows on a fresh install. This time I didn't install the user experience improvement program. Thanks for the help/response though!
    Apr 2012
    498
    13,501
    Quote Originally Posted by heythere88 View Post
    Good stuff! I'd have probably done the same. Fresh start without the extra spyware.
Tags for this Thread
