Results 1 to 10 of 10
    ROG Member Array leader.desslock PC Specs
    MotherboardAsus ROG Maximus X Formula BIOS 1602
    ProcessorIntel Core i7 8086k
    Memory (part number)Ballistix Tactical 32GB Kit (2 x 16GB) DDR4-3000 UDIMM
    Graphics Card #1EVGA GeForce GTX 1070 SC2 GAMING, 08G-P4-6573-KR, 8GB GDDR5, iCX
    Sound Cardon board
    MonitorAsus V247
    Storage #1SAMSUNG 970 EVO M.2 2280 500GB PCIe Gen3. X4, NVMe 1.3 64L V-NAND 3-bit MLC Internal Solid State Dri
    Storage #2Western Digital 2Tb Black SATA 6
    CPU CoolerNoctua NH-D15 SSO2 D-Type Premium CPU Cooler, NF-A15 x 2 PWM Fans
    CaseCooler Master HAF X
    Power SupplyEVGA SuperNOVA 750 G2 220-G2-0750-XR 80+ GOLD 750W
    Keyboard Microsoft Natural Ergonomic 4000
    Mouse ASUS Evolve
    Mouse Pad Kensington ergonomic
    Headset/Speakers Logitech Speakers
    OS Microsoft Windows 10 Pro Retail
    Accessory #1 Western Digital My Passport 4Tb
    Accessory #2 Seagate Expansion 1Tb
    Aug 2018
    13
    Intel Management Engine necessar under Windows?
    Hi
    I reinstalled Windows 10 Pro x64 v1803. *I downloaded drivers from Asus website, Intel and Nvidia and installed them. *I made a point not to use the Asus DVD. *I noticed that the dvd had the Intel Management Engine which i did not install. *I believe that I downloaded the latest version from Intel. *Do i need to install it?
    Thanks
    leaderdesslock *
    Dec 2011
    354
    25,742
    Mate you do not need it. If you ever plan on using remote access to your system then you will need to install it.
    Sound Cardon board
    MonitorAsus V247
    Mouse ASUS Evolve
    Aug 2018
    13
    Quote Originally Posted by HiVizMan View Post
    Thanks
    leaderdesslock
    ROG Guru: Yellow Belt Array Mr. Fox PC Specs
    Mr. Fox PC Specs
    Laptop (Model)- NA -
    MotherboardEVGA X299 Dark
    Processori9-7960X @ 5.2GHz
    Memory (part number)32GB Corsair LPX DDR4-4000 @ 4200
    Graphics Card #1EVGA RTX 2080 Ti xC2 Ultra Gaming
    MonitorPredator XB271HU 2560x1440 165Hz
    Storage #1512GB 960 Pro x 2 (OS Boot Drives)
    Storage #2960GB Samung Enterprise NVMe SSD x 2 | 2TB HDD
    CPU CoolerDual 360MM XPSC Rads+1/2 HP Water Chiller
    CasePraxis WetBench
    Power SupplyEVGA SuperNOVA P2 1600W
    Keyboard Corsair K95 RGB
    Mouse SteelSeries Sensei Wireless
    Headset Skullcandy Crusher Wireless S6CRW
    Mouse Pad Black Anodized Aluminum
    Headset/Speakers Logitech Z506 5.1 Speaker System
    OS W10 Ent LTSB 2016 / W7 Ultimate (Dual Boot)
    Accessory #1 Hailea HC-500A 1/2HP~790Watt Water Chiller
    Mr. Fox's Avatar
    May 2018
    41
    126
    You will have a malfunctioning entry in Device Manager without drivers, but Windows will work fine without it.
    As an alternative, you can get the INF-only (not AMT software) drivers from the WIN-Raid forums and install using the "have disk" method in Device Manager and that will fix the problem device without drivers if that bugs you.
    Punisher | EVGA X299 Dark | i9-7960X @ 5.2GHz | 32GB Corsair LPX 4000 @ 4200 | EVGA 2080 TI xC2 HydroCopper Block
    EVGA SuperNOVA 1600W P2 | 2x 512GB 960 Pro / 2x 1TB Enterprise NVMe / 2TB HDD / 4TB HDD | W10 / W7 (Dual Boot)
    2x XSPC RX360 | Praxis WetBench | Hailea HC-500A (1/2HP~790W) Water Chiller | Results:
    http://hwbot.org/user/mr._fox/
    Sound Cardon board
    MonitorAsus V247
    Mouse ASUS Evolve
    Aug 2018
    13
    Quote Originally Posted by Mr. Fox View Post
    I installed all the drivers. I especially installed the Intel driver.
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    Leaving IME uninstalled can actually secure the machine vs IME attacks/vulnerabilities. At least in theory.
    More importantly, leaving it uninstalled means less junk running in memory and consuming CPU cycles, more lightweight performance, less sluggish bloat, fewer things that can go faulty and buggy and crashy. Let WinOS complain about a missing driver, ignore that annoying little yellow caution icon, it doesn't mean anything important.
    [/Korth]
  7. #7
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,405
    Dear leader.desslock
    We'd just like to point out that IME is a valued part of any system. It allows various things to happen seamlessly on your PC such as stuff and whatsits. It is therefore generally advisable to install it to g̶i̶v̶e̶ ̶u̶s̶ ̶2̶4̶/̶7̶a̶c̶c̶e̶s̶s̶ give yourself peace of mind.
    The main component of Management Engine interface, ME performs a number of tasks in conditions when the system is running or in sleep mode. It also supports several tasks during the boot process. This sub-system is required for proper functioning and maximum efficiency of the PC. The interface checks whether the system is working properly or not while communicating with the operating system of PC. Which ...errr....means...err...well, look here now...if you don't install it well, it might...err.....not....yeah, it might not. and you don't want it to not.
    It's probably not advisable to ask these questions and to spend time viewing your favourite reality TV programming.
    All the best.
    Us
  8. #8
    ROG Guru: Orange Belt Array Snakeyes's Avatar
    Dec 2012
    42
    276
    Quote Originally Posted by arne saknussemm View Post
    dear leader.desslock
    we'd just like to point out that ime is a valued part of any system. It allows various things to happen seamlessly on your pc such as stuff and whatsits. It is therefore generally advisable to install it to g̶i̶v̶e̶ ̶u̶s̶ ̶2̶4̶/̶7̶a̶c̶c̶e̶s̶s̶ give yourself peace of mind.
    The main component of management engine interface, me performs a number of tasks in conditions when the system is running or in sleep mode. It also supports several tasks during the boot process. This sub-system is required for proper functioning and maximum efficiency of the pc. The interface checks whether the system is working properly or not while communicating with the operating system of pc. Which ...errr....means...err...well, look here now...if you don't install it well, it might...err.....not....yeah, it might not. And you don't want it to not.
    It's probably not advisable to ask these questions and to spend time viewing your favourite reality tv programming.
    All the best.
    Us
    awesome !
    NAME THE SANDWICH: – White Bread, Lots of Baloney, Russian dressing and served with a small pickle.?
    Intel Core i7 8700K @5.1 Stable Delidded
    Asus Maximus X Code
    16 GB
    G skill TridentZ DDR4 ​4266 (PC4 34100)
    Corsair HX1000i digital
    EVGA 1070 GTX TiSuperclocked+
    Samsung NVMe SSD 960 pro M. 2
    Samsung 860 Pro
    Watercooled with EK block radiator fans etc.
  9. #9
    Dec 2011
    354
    25,742
    Classic Arne.
  10. #10
    Apr 2012
    481
    13,405
Tags for this Thread
