Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    New ROGer Array
    Nov 2018
    1
    Motherboard Start light always on
    I have a Maximus XI Hero motherboard and when I shut down my pc (psu switch is flipped on), the “Start” button light remains lit. Is this normal?
    ROG Guru: Yellow Belt Array no1yak PC Specs
    no1yak PC Specs
    MotherboardMaximus Hero X I Wi-Fi/ Hero IX
    Processori9 9900KF/ i7 7700K both @ 4.7Ghz
    Memory (part number)Gskill F4-3200C16D / Corsair 2400 LPX
    Graphics Card #1Evga GTX 1070 SC ACX3 / Evga 1060 SC
    Sound CardEssence One DAC Muses edition
    MonitorEizo CG275W/ Dell U2719D
    Storage #1Samsung 970 EVO Plus NVMe / 950 Pro
    Storage #2Samsung EVO 950 Pro M.2 + 850 Pro 1TB
    CPU CoolerCorsair 150i pro/Noctua NHu-14S
    CaseCorsair 500D/ Corsair 450D
    Power SupplyEvga 650 P2 /Corsair HX750
    Keyboard Cherry MX6
    Mouse Corsair M65
    Headset/Speakers Corsair SP2500 + Senn HD650 + HD 600
    OS Windows 10 Pro x64 20H2
    Jun 2015
    156
    Yes the start light stays on, it's normal.
    New ROGer Array
    Nov 2018
    2
    I guess you are talking about the "Standby"-LED, right? Is there a possibility to switch the LED off when the PC is not running? If not, is there a possibility to switch the LED off if the PC is running?
    Thanks
    P.s.: I'm using a ASUS Z370-I, if thats important
    no1yak PC Specs
    Keyboard Cherry MX6
    Mouse Corsair M65
    Jun 2015
    156
    Quote Originally Posted by xamo1337 View Post
    Thanks
    No he's talking about the start button light ,please read the post before replying.
    The start button light is permanently on when you turn off the PC unless you disconnect the power from the PSU on a Hero XI.
    Dec 2011
    354
    25,742
    That is as it should be, when power supply is on, their is power to the board and the on button is lit up.
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    164
    7,453
    Quote Originally Posted by JohnBob128 View Post
    Try enabling 'Stealth Mode' in UEFI.
  7. #7
    ROG Guru: Yellow Belt Array pndiode PC Specs
    pndiode PC Specs
    Laptop (Model)ASUS G752VL-DH71
    MotherboardROG Maximus XII Formula
    ProcessorI7-10700K
    Memory (part number)G-Skill F4-3600C19Q-32GTZRB
    Graphics Card #1ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block
    Graphics Card #2ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block
    MonitorLG UltraGear 32GN50T-B
    Storage #1WD Black SN750 1TB
    Storage #2WD Blue 4TB (4 ea)
    CPU CoolerEK SE 360 (Top), SE 240 (Front), and Xres 100 Elite
    CaseROG Strix Helios white Edition
    Power SupplyThermalTake Toughpower 1200W
    Keyboard Cerberus
    Mouse Logitech MX Master S2
    Headset ROG Strix Fusion 300
    Mouse Pad Generic
    Headset/Speakers Bose Companion 3 Series II
    OS Win 11 Pro 21H2
    Network RouterGeneric
    Accessory #1 Corsair ML140 (4 ea), Corsair ML120 (3 ea)
    Jan 2016
    31
    248
    Yep!
    BIOS Advanced\ROG Effects\Onboard LED will turn on or off all onboard LEDs.
    BIOS Advanced\APM Configuration\ErP Ready Enable (S4+S5) switches off all LEDs when you shut down your computer (even the BIOS reset light, Start button light, and USB ports).
  8. #8
    Mar 2016
    8
    227
    Quote Originally Posted by no1yak View Post
    What? No, it's not normal....it's the default setting in Bios, and you can change it. How about do some research or read the manual instead of posting bull. You don't know anything.
    In Biios under Rog Settings -> you should change to "stealth" when the computer sleeps or off. This wil turn off ALL LED and AURA lights when you turn off your computer.
    I
  9. #9
    Mar 2016
    8
    227
    What? No it's not......How about reading the manual before posting this.
    In Bios under Rog Effects you choose stealth mode when the computer is off or sleeps...and ALL led and Aura lights will turn off when you shut down the computer.
  10. #10
    Mar 2016
    8
    227
    Quote Originally Posted by HiVizMan View Post
    No...you can change it in BIOS under Rog Settings. Choose Stealth mode when computer is off or sleep.
