Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    ROG Guru: White Belt Array
    Aug 2013
    106
    RYUO 240 pump and fan speed
    I have my RYUO 240 connected to the CPU fan header (per the documentation). In AI Suite (latest version), adjusting the CPU fan speed does nothing. When choosing the RYUO fan, the pump speed is supposed to be adjusted but I think it's adjusting both the fans and the pump. The AI Suite naming is also confusing...where it reads "RYUO fan"...but then states to change the slider to affect the pump speed. Can someone clarify?
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    Since these coolers are so new you may not find anyone here who has one to compare
    ROG Guru: Blue Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardMaximus Hero XI
    Processor9900k @ 5.1Ghz All Core 1.315v AVX -2
    Memory (part number)Gskill GTZ 4133 C17 32GB (4x8GB)
    Graphics Card #1ROG Strix 2080 TI OC
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 970 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 970 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks Evolv X
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur VOID Pro
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    80
    961
    This is how I connected my RYUJIN 360. Yours should be similar:
    Connect the RYUO fans to the RYOU fan connectors, not the motherboard
    Connect the RYOU to the AIO Pump connector on the motherboard
    Under AI Suite Fan Expert, RYOU Fan curve will adjust the fans, and AIO Pump curve will adjust the pump
    If you do not have a AIO Pump connector on the motherboard, use the CPU Fan. However you will need to make sure you have set Q Fan or other UEFI fan control to disabled otherwise AI Suite will not be able to take control.
    New ROGer Array
    Nov 2018
    1
    Hi , i have a Ryujin 240 and when i try to use preset on AI Suite (i have 4 preset) he put all the fans at the maximun speed.
    Think i have some bios settings in conflict, where i can find Q Fan settings in z390 strix asus motherboard bios? thx
    Quote Originally Posted by mdzcpa View Post
    mdzcpa PC Specs
    Sound CardOn Board
    MonitorROG PG348Q
    OS WIN 10 Pro
    Nov 2011
    80
    961
    Quote Originally Posted by Gilgamessh View Post
    Those presets do not work with the RYUJIN or RYUO. Instead start with the a basic preset, then custom adjust the fan curves as you want, including the PUMP and FAN speed of the ROG Cooler. Then safe those settings to a CUSTOM Profile. You can save various profiles.
    Also, I find the CPU Fan header is more effective and responsive for adjusting the Pump speed. Connect to the CPU fan header if you find the AIO header is not responsive enough.
    ROG Junior Member Array
    Feb 2018
    1
    I've just check the RYUO on my system (several weeks after install!) and the AIO PUMP is in smart mode running at 100%, I assume there is no hard in running the pump at 100% (the system is not on 24/7 or anything - maybe a few hours a day)?
  7. #7
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,548
    I run the pump at 100% constantly on every AIO I have used except EK
  8. #8
    mdzcpa PC Specs
    Sound CardOn Board
    MonitorROG PG348Q
    OS WIN 10 Pro
    Nov 2011
    80
    961
    Quote Originally Posted by faxfan2002 View Post
    Likely no harm done. I run mine on a fan curve to make my system absolutely silent during desktop chores.
  9. #9
    ROG Guru: Orange Belt Array Gofran PC Specs
    Gofran PC Specs
    MotherboardROG MAXIMUS XI FORMULA
    Processori9-9900K
    Memory (part number)F4-3200C14D-32gb
    Graphics Card #1Asus ROG STRIX GTX 1080 Ti
    MonitorDell 2417dg
    Storage #1970 evo 500gb
    Storage #2951 nvme 500gb
    CPU CoolerROG RYUO 240
    Power SupplyAsus RoG Thor 850W
    Keyboard Asus claymore
    Mouse Asus Spatha
    Mouse Pad Asus rog sheath
    OS Windows 10
    Accessory #1 Phanteks Evolv x
    Mar 2016
    11
    287
    please help i have two noctua fans connected to y but the fans keep going full what can i do provide picture or step by step please
  10. #10
    mdzcpa PC Specs
    Sound CardOn Board
    MonitorROG PG348Q
    OS WIN 10 Pro
    Nov 2011
    80
    961
    Quote Originally Posted by Gofran View Post
    I provided answers directly to your own thread here: https://rog.asus.com/forum/showthread.php?108656
