Results 1 to 10 of 20
Thread: XMP 1 and XMP 2 difference
11-11-2018 03:02 AM #1
- Join Date
- Aug 2013
- Reputation
- 10
- Posts
- 120
I just upgraded from a Z270 to Z390 using the XI Code. I moved the G.Skill RAM from my other system. On the Z170 I only had 1 XMP option. On this new board I see 2. What's the difference and which one should I choose?
11-11-2018 03:34 AM #2
Zammin PC Specs Motherboard ASUS ROG Maximus XI Formula Processor Intel 9900K (Conductonaut Applied) Memory (part number) G Skill 3200Mhz Trident Z RGB 32GB 3200Mhz CL16 Graphics Card #1 RTX 2080Ti FE Monitor Acer Predator XB271HU 165Hz Storage #1 Samsung 970 EVO 2TB M.2 NVME SSD Storage #2 Samsung 860 EVO 1TB SSD CPU Cooler EKWB Velocity RGB Case Lian Li PC-011 Dynamic Power Supply Corsair RM1000i Keyboard Corsair K95 Platinum RGB Mouse Steel Series Rival 600 Headset Astro A50 (Gen 2) Mouse Pad ASUS ROG Scabbard Headset/Speakers JBL LSR305 Mk II OS Windows 10 Pro 64bit
- Join Date
- Mar 2018
- Reputation
- 13
- Posts
- 233
I ran into this last night. Using G Skill ram as well, 3200mhz C16 Trident Z RGB. XMP 1 is the same as XMP on last gen in that it changes the 4 main timings, clock speed and voltage. The motherboard basically handles the rest. XMP 2 changes the above and a whole tonne of other RAM settings (on my system at least) and in my case it made my system very unstable. Games kept crashing and stuttering. XMP 1 seems to work fine.
11-11-2018 03:38 AM #3
Korth PC Specs Motherboard ASUS X99 R5E (BIOS2101/1902) Processor Haswell-EP E5-1680-3 SR20H/R2 (4.4GHz) Memory (part number) Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15) Graphics Card #1 NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB) Graphics Card #2 NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB) Sound Card JDS Labs O2+ODAC (RevB), USB2 UAC1 Monitor ASUS PG278Q Storage #1 Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0 Storage #2 Comay BladeDrive E28 3200GB SSD, 8xPCIe2 CPU Cooler Raijintek NEMESIS/TISIS, AS5, 2xNH-A14 Case Obsidian 750D (original), 6xNH-A14 Power Supply Zalman/FSP ZM1250 Platinum Headset Pilot P51 PTT *modded* OS Arch, Gentoo, Win7x64, Win10x64 Network Router Actiontec T3200M VDSL2 Gateway Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19) Accessory #3 ASUS OC Panel I (FW0501)
- Join Date
- Mar 2015
- Reputation
- 152
- Posts
- 2,719
They're just pre-programmed SPD profiles. Use whichever one runs faster if you like (unless one profile doesn't run stable). If you've manually configured your memory timings then the factory preset SPD/XMP/etc profiles would be ignored anyhow.
[/Korth]
11-11-2018 08:14 AM #4
XMP I is the validated board profile that you will have seen on past generations. Every time a board is validated, this profile is the one used by the memory vendor and ASUS. On Z390, there is now the option to use the DIMM profile which is XMP II. These settings are not validated, so mileage will vary depending on the kit and CPU.
XMP I - Board optimised timings
XMP II - Default XMP timings
Often, XMP II timings will be slightly looser depending on the memory kit. If you check within the UEFI or memtweakit, you'll see a difference in memory subsets.
11-11-2018 05:28 PM #5
- Join Date
- Oct 2018
- Reputation
- 20
- Posts
- 4
11-11-2018 05:39 PM #6
11-11-2018 05:58 PM #7
- Join Date
- Oct 2018
- Reputation
- 20
- Posts
- 4
11-11-2018 08:27 PM #8
- Join Date
- Mar 2015
- Reputation
- 152
- Posts
- 2,719
@ASUS ... lol I wish ASUS gave us a little more documentation about stuff like this ... so we'd actually know the features exist.
I mean meaningful documentation which actually tells the end user what features are there, what they do, what changing them will do.
Not uninformative nonsense like "Enable/Disable setting = enables or disables setting in BIOS" lol.
I don't feel it should be the consumer's responsibility to have to constantly monitor and report to support forums to basically read stuff unanswered in the user manual."All opinions are not equal. Some are a very great deal more robust, sophisticated and well supported in logic and argument than others." - Douglas Adams
[/Korth]
11-11-2018 08:32 PM #9
11-11-2018 10:09 PM #10
- Join Date
- Mar 2015
- Reputation
- 152
- Posts
- 2,719
[/Korth]
