G20 with RTX 2070, works fine!
annyh1lator
Photo: https://imgur.com/a/HJaVskR
Hi, 2 days ago i successfully upgraded my g20 to rtx 2070 (asus turbo version). Works fine and great performance in 1440p.
8 REPLIES 8
simmevoncilli
Which model of G20 do you have? What was your previous gpu? Did you have to do anything special with the power connectors/pins?
G20AJ, previous gpu - gtx 1070, nothing special, just 8+6pin
Great. Is the performance boost big over the 1070?
What about temperatures?
+~35% against 1070. 76C with auto fan speed (~40%). When you manually increasing the rotational speed of the turbine to 60%, the temperature drops on average to 65С under peak load.
megren21
what about psu , did you change it ?
nope, stock psu - 180+230
cityhunter62
Thank you for the informations, really helpful (even if dated) ! Will try myself with the Asus 2070s turbo. Wish me luck !
Did you have to move some kind of jumper pins around on the inside? Heard that in order to use both PSUs we have to move a small thingie one tad to the left?
