Results 1 to 4 of 4
    New ROGer Array
    Nov 2018
    3
    How can i turnoff my rog strix 700 headset poping sound it feeling very noise
    how can i turnoff rog strix 700 headset poping sound
    Administrator Array MasterC@ASUS's Avatar
    Aug 2014
    110
    1,565
    What is the Fusion 700 connected to and how? (wired or wireless)
    When do you hear a popping sound?
    New ROGer Array
    Nov 2018
    3
    reply
    headset fusion 700 is connected to my phone with bluetooth
    the popping sound is starter after i use 2 or 3 hour
    i try turnoff the bluetooth and open again
    it same happen again
    Aug 2014
    110
    1,565
    Quote Originally Posted by LouisTeo View Post
    What phone are you connected to and could distance be an issue?
    Some games and apps may have this issue no matter what BT audio device you are connected to, they will need to provide an update. Real Racing 3 for example could not play properly over Bluetooth until recently.
    Do you hear any popping sounds when connected to the PC via USB?
    Do you hear any popping sounds when connected to the PC via BT?
