Oc Tuner 1 or 2
NIK111
Can anyone tell me what the difference is with Oc Tuner 1 or Oc Tuner 2 in Ai Suite 3..Also if I run a auto OC will my saved manual oc profiles still be there or will they be gone..Just like some info before I try this..
4 REPLIES 4
__AFT___Requiem
OC Tuner 1 is for air cooling, OC Tuner 2 if you have watercooling.
NIK111
Right on..Thanks for the info..Do you know if I try this will all my OC profiles still be there in the bios in case I don't like what the auto OC generates..
Ashwind
Any OC profiles you have saved in your bios will be still there if you use the auto OC, do check before what the max voltage is for your cpu though, I tried the aisuite auto oc a couple weeks ago and it did give me a high oc but my core voltage was at 1.54 v the max for my 6700k is 1.45v (think 1.35 max is what intel say)
This much over voltage would have caused damage to my pc if I had not noticed and carried ou using it for a period of time
NIK111
Ok..Thanks for the Warning/Tip..Maybe it's best then just to stick with manual oc I suppose..
