Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 47
  1. #21
    New ROGer Array
    Jan 2019
    2
    How to Solve
    I was having the same issue (GL703GE). Didn't remember exactly when that happened, but I think it happened after I updated the nVidia GeForce Graphics Driver to the latest version.
    I am able to solve this by uninstalling all nVidia Driver from control panel, and then install the nVidia Driver from it's backed up folder. Mine is located here :
    C:\eSupport\eDriver\Software\Driver\Legacy\Graphic \NVIDIA\Graphic\23.21.13.8873\8292
    That's all I did, I don't update OS or BIOS, only playing around nVidia Drivers.
    Now it still happens after I boot up my laptop, but only for 5-10 mins. Not the whole times -_-
    If it still runs the higest RPM, try to test your GPU using FunMark. Do the 1080(FHD) or 720 benchmarks.
    Hope this can helps.
    Edit (3 days later) ::
    The issue still happens. Damn. I go to Asus Service Center to ask about this problems. He (the CS) said there are several unit having this problems (and why Asus don't fix it -_-). So he said some recommendations to me:
    1. Update your BIOS to the newest. If it still not fixed it.
    2. Probably the fan itself or the heat trigger is error. Give your laptop to them so they can examine your fan problem.
    3. The worst, motherboard burnt...
    EDIT 2 ::
    Fixed by Asus Service Center -_-
    They said the cable or connector or whatever didn't work properly.
  2. #22
    ROG Member Array
    Jan 2018
    11
    8
    Quote Originally Posted by chaaards View Post
    EDIT 2 ::
    Has it been working fine since ?
  3. #23
    New ROGer Array
    Apr 2019
    4
    Fix for GL504GW
    I hate to necro a thread but... I found a fix.
    CPU fan (left fan) was running at max, even in BIOS and Safe Mode.
    I updated the BIOS and all software, including Win10 with no luck.
    Got rid of Armoury Crate & Service.
    Installed GPUTweak II - https://www.asus.com/us/site/graphic.../gpu-tweak-ii/
    The fan is now quiet, around 5500 rpm even in the BIOS. Drops to near silent / silent when under low load.
    Of note- the GPU fan disappeared from Armoury Crate after the BIOS update and is still no longer listed if reinstalled.
  4. #24
    New ROGer Array
    Jun 2019
    1
    GL703GE GPU fan stuck on high
    I had fan problems on my new GL703GE - GPU fan would get stuck on high no matter what process or task I was working on. Tried every trick I found here and ended up sending it in under warranty. It's been a week and we shall see what they say the problem is.
  5. #25
    New ROGer Array
    Aug 2018
    3
    Quote Originally Posted by topcad View Post
    So did you get your laptop back? What did they said problem was?
  6. #26
    New ROGer Array
    Apr 2019
    4
    BIOS update
    The recent BIOS update coupled with the removal of Armoury Crate and using GPU Tweak II instead has cleared up the issue for me.
  7. #27
    New ROGer Array
    Aug 2018
    3
    Well i have ROG GL703GE and BIOS Version 318.
    Before update of BIOS i would run FurMark and vents would get silent but after this update they are always running like crazy
  8. #28
    New ROGer Array
    Apr 2019
    2
    The only answer that works so far.
    GL703GE, (GTX 1050Ti)
    I have tried everything I have read here or elsewhere. The fan goes to full speed randomly for no reason. Furmark sometimes calmed it down quickly, other times, even it did not work. Asus had my machine TWICE, the second time replacing the motherboard apparently. That didn't help. drivers, fresh windows installs, ASUS tools, 3rd party tools... nothing helped. What I noticed was that the problem would go on for a couple hours, every 5 or ten minutes, and then suddenly, it would calm down and stay calm, for the rest of the day.
    So, the ONE solution I have found was waiting until it calmed down one day and then I didn't shut my machine down at night. I reboot it every day or so, but never leave it shut down for any time at all.
    Bios 318 + GPU Tweak II + Latest NVidia Drivers + Power settings to never sleep and turn off monitor after 15 minutes, and I suspend Windows Update. I check manually for updates every week or so. I actually have no idea if anything of that helped.
    So far, it has been about 3 weeks now that the fans have not gone crazy. They have occasionally sped up a bit for no reason, and cycled up and down a little bit once or twice, but nowhere near the 5900 RPM they would hit before. In fact, I would not have even noticed were it not on my lap at the time.
    So, something is still not "fixed", but the machine is fine as long as I don't shut it down. It has been entirely tolerable.
    EDIT: Last week when I manually ran Windows update, there was an update of some sort from Asus (I forget what). I am not sure if that also helped.
  9. #29
    New ROGer Array
    Oct 2019
    1
    problem solution - works
    Hello. The only solution that I was able to do and work is to change the "power options" settings in the system. Each profile has been changed in the advanced processor power management / cooling settings from active to passive. GL703 laptop operation has returned to normal. In the gaming center set "fan overbost".
    None of the programs for controlling fans or processor management are working. Updating the bios did not bring anything - I have the latest one on which the computer worked normally. Changing the Nvidia drivers to older ones also did not change the thread even after a clean installation. It's possible that the changes were on the windows side - I haven't tested the chipset firmware update
  10. #30
    New ROGer Array
    Apr 2019
    1
    I've had the GL704GW for about 6 months and the fan issues were VERY annoying. Only thing that helped, COMPLETELY, is re pasting.
    ASUS assemblers are drunken monkeys when it comes to the thermal paste. It was uneven, sloppy, just a huge mess. The longest, hardest part of it (the only hard part, actually, if you are smarter than certain drunken monkeys) is cleaning the old paste, which is globbed liberally everywhere except where its most vital. There was not much at all on the GPU or CPU, and way way way too much on the rest of the chipset. It looked like a tube of toothpaste had been emptied. Also, 4 of the screws on the heat pipes and cooling assembly were so loose I'm amazed they weren't rattling around in the case.
    Good thermal paste is cheap, and the results for me have been amazing. Thermals are averaging 3-5C cooler at low idle, and 1-2C cooler on average when gaming. And I haven't had random fan ramping, or thermal throttling since I did it. It has been almost a week. Its not difficult. If you don't have experience doing it watch a few vids on youtube to get familiar with the process.
Tags for this Thread
